RTH: time between pressing button & action announced???
P4P+, bought 12/2016;
set to 327 ft ceiling & 327 ft distance;
for only 2nd time, I had "strong wind" emergency & resorted to RTH button; ? ? ?
I had gone to 327 ft distance & then saw distance continue to as much as 500+ ft;
after pressing RTH, I immediately lowered height to ~200 ft or less & also
tried manually bringing drone closer to take-off area;
it seemed like it took 15+ sec from time I pressed RTH to hearing
"Return to Home" activation announcement; (which was successful)
in fact, how long after pressing RTH button does RTH action commence? ? ? ?
do manual actions immediately after pressing RTH button delay RTH announcement?
We abuse the RTH function and it takes about 3 seconds from the press and release to activate it.
Phantomrain.org
coal
see OP;
distance set to 327 ft;
but wind pushed to 500 ft;
then pressed RTH;
then descended from 327 ft height limit to about 200 ft;
& then P4P+ RC announced "RTH"
(edge of Everglades, some trees around)
see OP;
then pressed RTH;
How long is is from the time you release the RTH button before the drone engages it , not announces it ?
I did not know there was difference between
announcing RTH & engaging RTH.
I ASSumed they were simultaneous...
Is there a screen message 15 secs
before voice announcement???
I did not know there was difference between announcing RTH & engaging RTH.
Is there a screen message 15 secs before voice announcement???
The best way to answer your queries would be to go to a nice open area and do some testing with the drone 60+ feet away and you can find out what's going on instead of wondering.
After pressing RTH the Phantom will hoover in place for a few seconds before it starts RTH.
In strong wind choosing RTH is not the best solution if the RTH path is against the wind. I would do that only if I am not sure where the craft is.
In RTH the craft moves slower as it uses less motor power to preserve the battery. In strong wind RTH may cause a trouble.
I'm thinking that the reception of the command signal and the true beginning of the RTH process starts before the voice is announced.
DonT
