RTH problem
Hallo Pilots!!
F-16 here... Im new phantom 4 pilot, i fly 3 or 4 months. Everything was fine until a week ago. I* started RTH mode with sensors but the drone just went heigher and heigher. I saw a conversation about the same issue from another p4 pilot but after i reset the drone and recalibrate the sensors nothing seems to get better. I got the same issue.
Can anyone helpme?
Thank you!!
F-16
Hallo Pilots!!
Can anyone helpme?
Thank you!!
F-16
Welcome!
We have seen this reported numerous times. Check out the thread below and the link it includes pertaining to FW.
Thank you for your immidiately response!
I have a few questions though.....
1) What is VPS
2)What is Gimbal Protector
I use the latest FW!!
Thank you to be so patient!!!
Yip welcome F-16
Gimble protector just a add on part that saves some damage if minor crashes ....VPS is the downward sensors,,mechanical sonar sends pulse to ground and back to help with the drone showing height and has monocular cams on either side of these little speakers,,helps with smart return home for accurate landings,they not work well over reflective surfaces ,,you can find heaps of info by downloading the online manual just with simple Google search,,its covers everything you need to know which normal booklet dont have....also check your RTH setting ,,it should stop at this determined height before rth fully engages
Reactions: MTO
Did you use the link pertaining to FW in the other thread as I mentioned earlier. If not, here it is again. It mentions how downgrading FW has helped multiple people with this issue. As with everything, your mileage may vary.
Hallo Pilots!!
If you can post the recorded flight data from the flight incident, I can check that to confirm whether the VPS sensors are the issue (or not).
Go to DJI Flight Log Viewer | Phantom Help
That will give you a detailed report of the flight.
Or .. just post the txt file here.
I Refresh The fw from DJI assistant before y yesterday flight
  • Sad
Reactions: Oso
Are my logs that files with .DAT??
I had one download to my PC from DJI assistant. But when i open the Flight data to read that it is empty
what am i doing wrong??
  • Sad
Reactions: Oso
If you updated to 810 go back to the previous version, problem solved. Happened to me also.after an update.
Reactions: Meta4 and Oso
tom sauter
