Re: Rotor Pixel Gimbal not working after Firmware Update 3.1
Hopefully this will be some usable information for all. This is direct from Rotorpixel and maybe should be posted here and if the administrators of the forum feel like it should be posted in another topic feel free to do so. Basically this will restore the default parameters in the RP control board. Thanks Keri.
Please follow these steps to re-format the gimbal control board and sensor:
1. Download the files here:
http://bit.ly/1qKhLxD
2. Install the USB driver first.
3. Run the gimbal software (SimpleBGC_GUI.exe).
4. Disconnect motors and pitch control cables from the gimbal control
board, and take note of the orientation of the cables. Only the
multi-coloured IMU
cable should be connected to the gimbal control board board now.
5. Connect the gimbal control board to your computer via any mini-USB cable.
6. Select the appropriate COM PORT in the drop down menu from the box
in the top left, and click CONNECT.
7. If it gives you an error stating a mismatch of the firmware with
the GUI, then proceed with steps 8-10. If no error occurs, and the
live read-outs on the right side of the screen are active when you
move the camera, then skip to step 11.
8. Run "XLoader.exe, select the correct COM PORT, and select
"SimpleBGC_2_40b7.enc.hex", then click "Upload".
9. The green light on the gimbal control board should go out for a few
seconds, and in the XLoader program it will eventually say "Upload
failed" - this is normal!
10. Now, try clicking "CONNECT" in the gimbal control software again,
and it should connect properly.
11. Click "Load" in the top right of the screen, and select "RPG-FC200.profile"
12. Click "Write" in the bottom right of the screen.
13. Rigidly secure the camera in a perfectly horizontal orientation
(might be easier without the camera installed), and click the "Calib
ACC" button once, then wait 5 seconds for the calibration to occur.
14. Click "Disconnect" in the top left, and reconnect the motor cables
in their appropriate positions/orientations.
15. Make sure that the camera is installed, and then try powering the
system up again.
Thanks,
Keri
