Reverse gimbal pitch wheel
I'd like to reverse the direction of the gimbal control wheel on my P3A (so that when I turn the gimbal wheel, the gimbal tilt works in the opposite direction to how it does now)
Is there a way of reversing that control channel?
I agree with you in that it seems reversed in operation and I often go the wrong way and then and go the opposite direction which looks bad on playback. They have Modes 1 and 2 for the control sticks so why not adjust that roller direction too? While at it, do the same for the camera exposure side as well.
However, you probably could if you reversed the leads at the roller switch. Problem is I think that switch uses a ribbon cable assembly so you'd have to somehow replace it with wires to do so.
I'm wanting to add another function to the shutter button on the opposite side and ran into the ribbon cable matter on the other side which is wider. Arrgh!
