replacing p3a camera with p3p camera
If I replace the camera/gimbal, I will get 4k quality. Is it as simple as it sounds? I read something about the p3p using a higher speed lightbridge...or does the hardware come with the camera set up itself?
Thanks.
The gimbal board above the camera will give you the 4k and the 10Mb/s downlink speed of the P3P, but most people who make the change just replace the camera/gimbal at the same time as a unit.
Then of course you need to install the P3P firmware instead of the P3A firmware.
Yep, I did it and the FPV clarity alone was fantastic. Can't recommend it enough! Just cut off the plastic pins holding everything together and unplug two cables - super easy.
Anyone knows where to find a good deal on these ?
Message Hunch here - he's a first-class gentleman and well regarded all around. Provided your Advanced gimbal/camera is in good shape, for that plus $200 he'll send you a brand-new factory Pro gimbal/camera and the extra hardware to attach it. Best money I've spent on any mod!
Reactions: scootrkitz
src72
