replacing p3a camera with p3p camera
Discussion in 'Pro/Adv Discussion' started by Reynaldo, Jul 17, 2016.
Tags:
  1. Reynaldo
    If I replace the camera/gimbal, I will get 4k quality. Is it as simple as it sounds? I read something about the p3p using a higher speed lightbridge...or does the hardware come with the camera set up itself?
    Thanks.
  2. Ted4797
    Florida and New York
    That is what I understand. I have done it.
    scootrkitz likes this.
  3. Oso
    Oso
    Western US
    The gimbal board above the camera will give you the 4k and the 10Mb/s downlink speed of the P3P, but most people who make the change just replace the camera/gimbal at the same time as a unit.
    Then of course you need to install the P3P firmware instead of the P3A firmware.
    JoBe, scootrkitz and Ted4797 like this.
  4. theTastyCat
    Yep, I did it and the FPV clarity alone was fantastic. Can't recommend it enough! Just cut off the plastic pins holding everything together and unplug two cables - super easy.
  5. BrandAL
    Anyone knows where to find a good deal on these ?
  6. theTastyCat
    Message Hunch here - he's a first-class gentleman and well regarded all around. Provided your Advanced gimbal/camera is in good shape, for that plus $200 he'll send you a brand-new factory Pro gimbal/camera and the extra hardware to attach it. Best money I've spent on any mod!
Similar Threads - replacing p3a camera Forum Date
Advanced advice with replacing long ribbon cable on camera on P3A Phantom 3 Help May 28, 2016
How do you know what needs replacing after a crash Canada Jan 9, 2018
Standard what else can i do rather than replacing Phantom 3 Help Nov 17, 2017
Replacing P4 Gimbal/Camera Unit Phantom 4 Discussion Oct 6, 2017
Replacing adhesive on flex ribbon Pro/Adv Discussion Sep 20, 2017
