Replacement of gimbal mainboard
Hello,
Do you know if It's possible to replace a p3p gimbal main board by a p3s one?
Thank you.
Hello,
Thank you.
No. You can only use a P3P or a P3A gimbal top (main) board with a P3P.
Keep in mind that the gimbal top (main) board is one of weakest parts of the P3Ps and DJI does not sell them. Use caution when buying a used one since there is a good chance the used one will also be bad. No Image Transmission is a very common problem.
You could try to fix yours by following the guide in this post.
Reactions: JoBe
Ok, thank you for your answer and for the link! great diagram !
I was ready to send it to Dji support but maybe i will try.
So, if i put a p3a gimbal main board in a p3p, i have to use a p3a firmware in the futur.
What functionality i Will lose ?
If you use a P3A gimbal top (main) board on a P3P, you will effectively change your P3P to a P3A. That would mean a lower and non adjustable downlink (FPV) bitrate of 2 Mb/s max versus a P3P downlink max of 10 Mb/s as well as having only a max of 2.7k recorded video versus a P3P max of 4k.
Reactions: JoBe
Little feedback:
I bought a 7€ usb-ttl, spend few hours in github and my gimbal works fine now :)
Video live on dji go is ok
Thank you for help
Reactions: quaddamage and Oso
fiweli
