Replace the broken cover UV P3 Pro
This is a fine lens that is very easy to break, with hardly pressure, mine broke without any reason (apparently).
If you're unfortunate enough to break it, you'll see it's just a protective anti UV filter also protects the actual lens from dust, buy original are 30 euros, fortunately for a third of that price you can buy an alternative the same function and that is really well as seen in the video.
It is very important not to make too much pressure on the rim, is made of aluminum and can be deformed easily, the trick is to use multiple fingers to rotate it to release.
I hope this video you can serve others in my case
