Red dot on the map.?
as far as im aware its the location of your controller. red means it has no gps and blue if it does. im pretty sure this is what it is as it just showed up on my maps recently done a search and this is the answer i found
Well when I see the red dot it! It indicates airport! This is some other kind of red dot?have not noticed that!
Sent from my SM-G900FD using PhantomPilots mobile app
Had a flight today. I checked on the map. Red dot still there. I zoomed in. It shows my home. Place pretty fly away from where I'm flying.
Pl advice what to do. Rte was done correctly. But why is the red dot involved
Meanwhile the last data on the left of the screen shows 11000 meters. When I was definitely not that far away.
Sent from my SM-T320 using PhantomPilots mobile app
SoLVed.
I figured out what it was. The problem was in the settings of my tablets GPS settings. The GPS priority mode was set to low. I switched it to high and it dot turned blue and was on a correct place on the map!
Thanks to all for your help and support!
Reactions: Neon Euc
SoLVed.
Glad you figured it out!
Which tablet are you using and how did you get to the setting u changed?
src72
