RC Channel settings
What is your setting here in DJI Pilot App? Sometime, when there are too many interferences I used to lock one channel manually (far from noisy frequence) in order to keep the signal stable. Other times I leave it auto.
I usually keep the bird hoovering in front of me half a minute or more to verify that all is ok before fly, during this check sometime I loose the signal for one or two times and then all ok. Maybe, during this operation the system try to switch channels in order to find the best.
Bye and greetings from Italy!
I don't like the manual setting here because you are checking for interference where you take off from but you could be flying for miles away from you. Just leave it on Auto. Unless you want to check in every place you might fly. Doesn't seem like a good option to try to pick the right channel for all the areas you will fly over.
Reactions: skyhighdiver
Nip
