Took my Phantom 3 Standard out for a flight this evening here in Arkansas. I got it up a good ways and out a good ways using line of sight. Before I sent it up I started the camera recording in video mode. I had it up for about 3 minutes and then the dreaded happened... My screen flashed DISCONNECTED, and my remote went RED!!
Panic started to set in a little bit so I patiently raised my arm up as high as I could get it to try to reconnect to the drone.. MAGIC happened. I got it connected and activated return to home... Then SATAN showed his ugly head and the wind picked up and pushed the drone over 300 yards further away from me as it was on its descent to the 30m return to home flight level....
Fortunately I had just bought an electric golf cart 8 days ago.. I hit the garage remote, ran in and jumped on it with the controller in my hand and trying to keep both an eye and ear out for the lights and buzzing of the blades.. I hit the pedal and NOTHING!!!!!!!!!!! It would not move!!! HEY DUMMY!! Put the key in and turn it on!! I did that, stomped the gas again.. NOTHING AGAIN!!!!!! I was literally about to poop a cat, kitten, dog, and a couple cows at this point!! I just got it (the drone) in after paying almost $500 for it... Reached down to check the direction switch... It was in NEUTRAL... I flipped it to reverse, stomped the pedal, and took off like a shot, whipped it around to ALMOST pull a Rockford, then flipped the switch and hit the pedal as hard as I could.. I was off to the races.. I could still see and hear the drone!! And I did NOT like where it was going!! I flew across the highway in front of the house (yes I looked both ways), hit the switch for the LED light bar, and I was off and running, at 10.3 MPH!!
I got close enough for the drone to reconnect to the controller, and the app to pick up so I could cancel the return to home feature and guide it to me. That's when I saw the BATTERY WARNING!! 28% and dropping like a rock!! I grabbed the altitude drop controller and hit the bottom lock on it! 2 minutes later it was low enough I could guide it to just in front of me, get it to where I could grab a leg and shut it down...
Happy ending!! Except for the frozen face, iceburg ears, frostbitten fingers, and foggy glasses!!
I have had problems with this one just randomly disconnecting since the very first flight. The last one I had flew like a bird and I never had an issue unless I got low on battery (to me 35% is LOW)... Then it only took me standing up and facing the drone to reconnect and get it back to me. This one though, it has choppy video, choppy reception, video signal not coming thru, all kinds of problems. So I will be contacting DJI tomorrow for advice and tech tips to see if I can get it flying right. I have tried it with an iPhone SE and an android device. Last one flew with the same iPhone SE, iPad 5th Generation, and iPad 3rd generation.
