i've got a phantom 3 standard and i have fitted a "ARG range extender" but i can still only get an altitude of 200ft and range of 250ft.
does anyone live near coventry who has a phantom 3 and can check my transmitter with there's?
Are you losing control signal or fpv signalHave you got any range limitations set in the app
Are you logged into the app, Rangel limitation applies if not.
Did you have the same issues before fitting the argtek
Has the quad ever gone further ?
flew it on a farm by a fishing lake and distances were shorter.
I think something is wrong with your remote control. And that can be the connection to the antenna. Re-open the remote control and check your connections. Often a connection error occurs at the connection to the printed circuit board.took the drone to the fishing lake today.
check the range limits on open ground.
any help to cure problem welcomed.
The fault you mentioned does not just happen. There is always a cause. When I look at your video, I see that there is an antenna error. Therefore my request to make a clear photo of it.I have opened my transmitter but everything looks ok, the antenna connections look ok.
Thank you for your photos. I think your antenna is not correctly connected. My advise to you is disconnect the connections again, clean the connections well (but always carefully) and reconnect them.Use a little of connection spray on the wire (not on the board). Then apply an insulation over the connection (using a glue pistol, for example). It is intended that the inner pins fall into each other.pics as requested.
Are you in "Beginner" Mode??i've got a phantom 3 standard and i have fitted a "ARG range extender" but i can still only get an altitude of 200ft and range of 250ft.
