Putting some RTB on the compass connector
I just want to throw this out there maybe someone has thought of this and if so what results or side effects have been experienced.
How about placing a small dap of RTB around the compass connector to make sure it stays secure and maybe prevent intermittent connections that can cause it spiral in a fly-away loosing control?
Maybe that is what happened to me today though I made sure all connection were good during pre-flight
see: viewtopic.php?f=7&t=7021
Jus saying....
Richard
rfernandez said:
I am just throwing this out there maybe someone has thought of this and if so what results or side effects have been experienced.
Jus saying....
Richard
+1
+1
I also noticed that on the circuit board inside my P2V, the plug lead from the GPS is not 'glued' like many other connectors. Maybe it is a good idea to put some RTV there, too.
Bresson said:
+1
sounds like sound advice
anyone done it yet any adverse effect
any signal problems if done
hmmmmmmm
I was talking to mmotown the other day and if its the same rubber substance on the connectors its called "liquid electrical tape", just found loads on ebay and it come in quite a few colours
Liquid Electrical Tape (LET) is easy to use, providing an airtight, waterproof, dielectric coating in minutes. The coating will last for the life of the application, yet it can be removed immediately as needed. One application will protect terminal connections or splices, as well as guard against vibrations that can loosen connections. It is UL-tested, easy to use and reliable.
yes im an electrician we use it in a spray all the time
but wondering if it will effect the compass if put on maybe waterproof the whole part
or do we need to do just the connector
skyhighdiver said:
Bresson said:
+1
hmmmmmmm
Tried it yesterday and everything goes normal. Just a little thing to give some more confidence.
