Putting some RTB on the compass connector
Discussion in 'Phantom 2 Vision Discussion' started by rfernandez, Jan 25, 2014.
  1. rfernandez
    I just want to throw this out there maybe someone has thought of this and if so what results or side effects have been experienced.
    How about placing a small dap of RTB around the compass connector to make sure it stays secure and maybe prevent intermittent connections that can cause it spiral in a fly-away loosing control?
    Maybe that is what happened to me today though I made sure all connection were good during pre-flight
    see: viewtopic.php?f=7&t=7021
    Jus saying....
    Richard
  2. amrflyingdude
  3. Peter Evans
    Lot-et-Garonne, France
    What is RTB, please?
  4. Super-D
    I'm thinking the OP made a typo and meant RTV Silicone.
  5. iDrone
    Los Angeles, California USA
    aka: GE Silicone Rubber
    iDrone
  6. Peter Evans
  7. OI Photography
    Clarksville, TN
  8. rfernandez
    Sorry i didn't noticed the misspelling on the Acronym.. yes it is RTV.. silicone adhesive.. if it needs to be removed i will come out with ease so s not permanent.
    Richard
  9. Bresson
    I also noticed that on the circuit board inside my P2V, the plug lead from the GPS is not 'glued' like many other connectors. Maybe it is a good idea to put some RTV there, too.
  10. skyhighdiver
    South Dakota
    sounds like sound advice
    anyone done it yet any adverse effect
    any signal problems if done
    hmmmmmmm
  11. NEILS
    I was talking to mmotown the other day and if its the same rubber substance on the connectors its called "liquid electrical tape", just found loads on ebay and it come in quite a few colours
    Liquid Electrical Tape (LET) is easy to use, providing an airtight, waterproof, dielectric coating in minutes. The coating will last for the life of the application, yet it can be removed immediately as needed. One application will protect terminal connections or splices, as well as guard against vibrations that can loosen connections. It is UL-tested, easy to use and reliable.
  12. skyhighdiver
    South Dakota
    yes im an electrician we use it in a spray all the time
    but wondering if it will effect the compass if put on maybe waterproof the whole part
    or do we need to do just the connector
  13. Bresson
    Tried it yesterday and everything goes normal. Just a little thing to give some more confidence.
  14. PAValentine
    Ft. Worth Texas
  15. Bresson
    Oops thanks. Luckily I just put some on the plastic part on the connecter. I guess the LET mentioned in a few posts back should be the solution on electronics.
Similar Threads - Putting RTB compass Forum Date
Anyone think about putting skis on the P4P? Phantom 4 Pro Discussion Jan 11, 2018
Phantom 4 pro motor clicks when putting propeller Phantom 4 Help Oct 23, 2017
Putting decals, stickers, etc. on phantom Phantom 2 Vision + Discussion Jun 13, 2017
Putting osmo mobile gimbal on osmo+? Osmo Mobile Apr 4, 2017
Putting solid lights on drone for photography? Phantom 4 Pro Discussion Mar 2, 2017
