Pressuring DJI to backout Enable Max Distance reset
As some of you know, ending a mission, and changing out a battery causes the Enable Max Distance button (in DJI Go 4) to reset to off (assuming you had previously set it to on/green/enabled). If you are a frequent Litchi user, you may well see this reset manifested in the following error message when starting waypoint missions: "Start Mission Failed - Over maximum flight radius".
(I happen to be flying a Phantom 4 Pro, but I suspect this kind of behavior might be found with the Phantom 4, as well. Not sure what other models the Go 4 works with)
I'll be looking for a way to pressure DJI to revert the software to the previous behavior on this issue, but if you have thoughts in that regard, please let me know.
