As most of you who've posted drone video to YT already know, YT crushes the bit-rate. For example, while the P4 encodes 1080p/30fps at 50 Mbps and 4K/30fps at 100 Mbps, YT will play back the 1080p at 8 Mbps and the 4K at just 35 to 45 Mbps. Higher compression (at lower bit-rates) reduces the clarity, making the video appear smudgy, especially where there's lots of movement on the screen.
On YouTube the difference between 4K and 1080p is significant, but you'll find that this is more a product of the bit-rate differential than the pixel count. The upshot is that even without a 4K screen, you're better off viewing the 4K version on YT. Of course, you'll only see 1080 pixels if you have a 1080p monitor, but it'll be a less compressed image than what you get if you stream the 1080p version. Try it for yourself.
I still see lots of drone video posted to YT in 1080p - which I find surprising. Most videos shot at 50 Mbps are a shadow of their former selves when streamed back at 8 Mbps. The more amateur the video (like my own), the more noticeable the quality loss. Streamed 4K video is also a shadow of its former self, but the difference is not nearly as marked.
So if you have the bandwidth, watch the 4K version on YT - even if you don't have a 4K monitor. And if you only have 1080p to upload, consider rendering your edited video in 4K and uploading the larger file. The streamed 4K version of your up-scaled 1080p video will be a much closer match - quality wise - to your original video!
The other advantage of uploading 4K is the VP9 codec. YT will encode a 4K video file in the more efficient VP9 codec. The entire resolution stack (4K down to 144p) will get the codec, where there's a clear improvement over the standard H.264. You can get VP9 on uploaded 1080p video files, but only if the video frame-rate is 50 or higher.
What are your thoughts on this topic? Why are people still shooting in 1080p? Are you one of those people?
