Please connect to Main Contoller
If any of you have seen this on your DJI Lightbridge app when first setting up your system - Here are the symptoms and the solution I found:
Symptoms: You see both the Connect & Video lit green on phantom Lightbridge. You see the video on the app. However you don't see any stats (height, weight, battery life) with an big red message that reads "Please connect to Main Contoller"
Resolution: Unplug and replug antennas on Phantom Lightbridge again.
Let me know if this helped anyone out there.
I'm really not sure that it is a good idea to disconnect the antennas when the LB is powered on and transmitting - you can damage the transmitter output stages.
