Phanton 2 vision + won't post
Saskatoon sk
Hi, I have not used my phantom in a while and the batteries were bad. I purchased 3rd part batteries. When I try to start up. I get a quick white flash on the LEDs then it starts beeping while it goes through a flash cycle.
I also tried a firmware reset...no change
Connect it to PC and see the error in logs there.
First check if Assistant shows something, if not - just open PuTTY and look at the messages logged at startup.
I wonder if you're fast enough to be able to capture the startup logs..
From the footage you sent I can't really tell if it's Ph2 on Ph3.. I assume you checked markings on the drone.
Its the Phantom 2 vision plus, as you have the range extender on the remote
that said the Beeping is the naza saying there is an issue, this could be a number of things, but the first thing I would do is connect it to the assistant software
I have a guide below to using the software
and if the software wont install watch this one
jeetbuzz360
