Phantom vision gimbal settings at start up
Medellin, Colombia - South America
Hi, because I was searching with no luck, I ask for your help.
Could any one of you guys, tell me where is the topic related with gimbal and it´s settings to avoid when the phantom is initialized and the camera moves down?
Maybe a month ago, I saw a topic related and the way to put the camera leveled when the system is initialized.
thanks for your help
Pull_Up said:
Try a setting of about -800 or so for the CENTER point in the gimbal settings, then fine tune for level. Then play with the Max and Min to make sure the servo isn't grinding into the stops at the ends of the tilt (try something like Max +650, Min -900 and again, tweak).
Try that.
Hi Pull_up, thanks one more time for your support, let me tell you that I set my gimbal at -600 and it is looks the way I wanted, as easy as 1,2,3
thanks!!
Supercell
