Now it's making more sense. I was thinking your compass was on the leg like mine!
ericty said:I sent an inquiry to my retailer to elaborate on this.deluge2 said:Well had to read the whole thread to fully understand the situation here. As you noted in your initial post, this may or may not work for others. Since this method was suggested, apparently, by you dealer, it might be interesting to ask what the known or presumed mechanism is by which this works. Is it indeed analagous to using a magnet directly on the compass unit when calibration is not possible (ie Colin Guinn's video)? If so, what is the source of the magnetic field?
Good suggestion. Done! Thanks SteveAlso, you might want to edit your initial post to make clear that this worked in a 'non-standard' Phantom configuration as regards the location of the compass module. If this works via influencing the compass module, then it would need to be done differently of 99.999% of Phantom users since the compasses are on the leg. Steve
