Phantom Batteries Maintenance
After about 30 charges on a fully charged battery I have done a full discharge by leaving the drone powered on but props off. It takes several hours to drain. I then wait about 12 hours before a full recharge and they work better.
How do you keep your camera cool?
One year with my 4 batteries (P4) and about 50 charges, I never discharged at 8%, I try to land at 20% sometime less cuz we all have a few more pics to take because the sun is just right. I store (50%) with dji hub after cooling and charge to 100% on fly day and sometime it may take 2 days to fly my last battery. I get the same results today as the first week I flew, I fly for about 20 minutes @ 30 mph and can cover over 40,000 feet and land at 20%, sometimes less distance but always around 20 minutes for 20% bat, when I get less time I was pushing the sticks and wind hard. My lowest battery life is at 96%. At this rate I hope these batteries will fit in a P5.
Reactions: HeadHunter2020
I do believe that the batteries controller will change the available power readings if you always shallow drain your batteries. I think that a full drain and charge will not give you more power in the battery but will give you access to the available power it has. If the battery software thinks it only has x amount of mah than you will get a critical warning and you may shut down regardless of the actual mah available. A full deep cycle may reset the batteries internal firmware to really see what is available. I said I sometime go bellow 20%, at times I even had to cancel auto land as I was coming in to land (maybe once per bat), this may be the reason they still give me the same output from a year ago. I have seen other post where the battery had almost no mah and with a full cycle they reset. There is many many variables that affect battery life so lets' share and learn.
Yup we can all learn from others experiences. I fly my drone to it's limits you might say on some flights. Most of my flights I do around 15 mins some are 20 mins. One rare one 22 mins but was close to home point for that.
Reactions: Erised
Having done some more research into this, DJI state in their current battery guidance notes for the Mavic, Inspire 2 and the Phantom 4 that you should cycle the batteries every three months. Even more odd therefore, that this advice should've been changed for the P3 - maybe it it was just an print omission after all.
Reactions: yorlik
Anyone have an opinion? I ask, as given they are all the same intelligent technology, this seems to contradict current thinking on the P3 batteries?
I think DJI is just recommending you use the battery once every 3 months. If they wanted you to cycle the battery, they would probably recommend you discharge it down to 8% or until it shuts off (like they used to recommend).
Thanks Mark. I'm not so sure that, quote "Fullly charge and discharge the battery at least once every three months" actually means use it, does it? I guess that given the statement is about as ambiguous as you can get, means its all about ones own interpretation. Wonder why the didn't give the same advice for the P3 batteries?
......I'm not so sure that, quote "Fullly charge and discharge the battery at least once every three months" actually means use it, does it?........
I would read that (discharge the battery) as use it.
I have no other way to discharge mine other than in the bird.
