- Joined
- Jun 6, 2023
- Messages
- 5
- Reaction score
- 2
- Age
- 30
The camera of my Phantom 4 Pro, after turning it on, suddenly moves smoothly and then faces downward. It doesn't stay straight to the horizon.Please help.
One possibility is a bad SD card.The camera of my Phantom 4 Pro, after turning it on, suddenly moves smoothly and then faces downward. It doesn't stay straight to the horizon.Please help.
Greetings DroneMata, please let us know if removing the SD card solved the issue. Alway handy to know these little quirks.
Regards
I have already replaced the Gimbal motor ESC board, but it's still the same. I am planning to replace the Gimbal camera IMU board located at the back of the camera case.Please helpTilt motor or gimble motor esc board (controls all 3 gimble motors), not difficult to replace. Thankfully I keep spares so trial and error is simple. Drone tools are your friend.
Was this issue ever solved as I currently have 1 camera/drone that does the same. And how was it solved? ThanksDroneMata - Did replacing the camera IMU fix your problem?
I am experiencing the same issue as you although maybe not quite as bad (after tilting down mine will drunkenly return to almost level after 4 for 5 seconds - although the camera is still facing down 5 to 10 degrees).
Also in flight lateral movement still has stabilized video but rotational movement results in the horizon quickly becoming out of level and the slowly returning to level after rotation stops.
Also when my drone powers up the camera will go through the usual movements and then center itself perfect. After about 3 to 5 seconds after centering the camera will jerk upward slightly then slowly (not real slow) move downwards to about 45 degress and then come back up to about 5 to 10 degrees pointed down. Pressing the C1 button will move the camera to slightly past 90 degrees and slightly below 0 degrees (around the same 5 to 10 degrees as the "new" zero).
I have tried multiple IMU and gimbal calibrations.
