Phantom 4 Gimbal Problem
Hi all,
I had a little crash, When I first started up the phantom 4 after the crash, camra did not work, left front sensor didn't work, and gimbal pitch reached maximum movement.
After taking apart, calibration ect. The only problem I have left is 1 error message Gimbal Pitch reached is maximum movement.
When I start drone, the camera does not do its little up and down then straight dance. It just kinda hangs there ..
My phantom 4; Flies good, takes pictures, video, and the camera gimbal status is normal.
I tried auto calibrate gimbal, it doesn't seem to do anything. I calibrated the IMU.
Any thoughts,
Gyro-BR
Then how was it? Mine also. Nothing happened before flight but when i start the AC the gimbal just start look up and down but it won't balance.. so it's like the phantom not on.
Have you check the ribbon cable its what gives power to the gimbal Motor
jeetbuzz360
