Phantom 4 gimbal noise at startup
I guy's and Girl's
Wan i power up my DJI phantom 4 i have this little sound at the end. I know that ALOT of person got the same problem!
Does some of you have resolve this issue ?
If yes How?
Do i need to worry about it?
This is 2 video that i found (they have many more on youtube) that discribe my problem
Sorry for the english!
It's normal. Don't worry about it.
I hear it too, I was getting worried about it, but I guess it's normal
So,,, what the h*ll
To remove the initialize Gimbal Noise
1 - with 1.5mm good allen key remove the 4 screws of the back Gimbal vertical cover ( pointed in the picture)
2 - take of the back vertical cover
3 - turn on the Phantom 4, probably the noise go out
4 - put in place the vertical back Gimbal cover without the screws
5 - put a little bit of paper glue in the screws to prevent vibration unscrew
6 - put back again only one screw and screw until the end
7 - unscrew 1 turn, turn on the Phantom and test, if the noise persist, unscrew 1 more turn and test again. Unscrew a little bit until the Gimbal not make more noise on initializing
8 - make the same all process to the screw number 2, 3 and 4, but only one at time
If works for you, please let me know
Hi Claudio, thanks for the solution, i did it and fix the gimbal noise but i not put paper glue. Only unscrew some screws and now not noise. Thanks!,
Fixed for me too.
Note in change log there is: "Changed the notification tone for gimbal initialization", but note sure as screws tip worked for some, so actually they might have a bit smoothen gimbal movement.
Update: for me was fixed by firmware but screws tip would have maybe helped - actually I didn't bother about the noise.
Don carlos
