Phantom 3 third light of Battery Flashing Continually
Cyprus
One of my battery when is full charged the third light of four lights is Flashing Continually. As you can see in video. Do we know what causes it and if it is a serious problem?
Page 21 of the P3P manual says that 2 blinks each second on 3rd LED shows OVERCHARGE detected.
I suggest you place in AC and see what GO says about the cell voltages ...
You should if any cell is over 4.35V - give it a short flight to discharge the cells to below the 4.35V volt mark - then leave to self-discharge as normal.
If it is only the one battery that did this and you others are fine ... then :
When you charge up next time - note if it happens again. If it repeats each time you charge - then something is wrong with battery ..... I suggest you retire this to less important roles such as updates / bench test duty.
How old is the battery ? If relatively new - you should qualify for replacement or refund.
Nigel
What is the battery warranty
Batteries are only covered for 6 months from the date the drone was originally purchased from DJI or the date the battery was purchased if it's a spare battery.
Reactions: Mark The Droner
