- Joined
- Oct 9, 2015
- Messages
- 12
- Reaction score
- 0
- Age
- 54
Hey guys if I were to buy this for my p3 standard;
1) will it be compatible?
2) is it worth my while? Thanks guys and girls
Anyone help with my question page 29? much appreciated
It is a pleasure to welcome you to the Phantom Pilots forum. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
I have made you your own first thread.
Be sure and post in the correct areas i the future. By 'hijacking' you are violating one of the forum guidelines and you won't get many people to see your question as it was buried in a different thread. You should have better results here. Also, you'll want to keep the images to about 600-800 pixels so members with slow connections aren't waiting all day for pics to load.
The antennas you listed are typically used for FPV systems and most likely not what you want. It really depends on what you want to do with it. What is your reasoning for changing the antennas? Are you gong for range?
Have you set the device for optimum performance? On the forums there is a list of things to check. It is mainly for iOS devices - HOW TO: Optimize Apple device for the best DJI Pilot app performance | DJI Phantom Forum
I don't have the same option, maybe that's on advanced and pro, should gimbal be set to fpv or follow?Look at #5 in the link LuvMyTJ gave ya and see it your set like that in your app .
Sorry but those are on my standard go app and is what I'm using and working great . Got me over 6000' stock but I'm not in CE .I don't have the same option, maybe that's on advanced and pro, should gimbal be set to fpv or follow?
I really want to fly far but I know it won't let me and I'm getting frustrated, probably end up selling if it can't do what it's promised, unless of course someone posts something helpful and refer me to a piece of hardware that will actually help, my software is fine and settings are good.
Maybe it's the way your aiming your antenna that's making you fall short .
You say "you really want to fly far" well you should have gotten the Adv. We are trying to get this to go farther and if you would read some you will see just how .I'm not going to refer you to anything as I don't know just what it would do for you. Every bird is different and again if you would read in here some more you would see that .I have the itelite panel on mine and has gotten me as far as 7500' so far but has not come close to that for others.
If (my software is fine and settings are good.) well maybe ya just got one that's not gonna do much and you need to sell it .
I would keep messing with the way I was aiming the antenna before I did .
I am Android.
I use either nexus 7 gen 2 (notablet holder)
Or my galaxy s6 edge.
I know it should be getting further then it is and its frustrating.
I want to be able to have solid connection at say 500meters( .3 mile).
Are you loosing video signal or remote signal?
I think you got a bad unit. I would send it in.
Read#15
RC Signal Lost | DJI Phantom Forum
I had a read of this posts, these peoples drones are only getting tiny distances, I can go about half of what "capabilities" they say it can achieve.
This is going nowhere. I asked one simple question, what Ariel can I use to replace the stock for a stronger signal/range. People beat around the bush on this forum.
Putting new antenna on a defective unit, and if doesn't work what do you got? A unit you took a part with no warranty.
Duh
Don't bother to reply, I am done with you.
You sir, are a wanker. Have a good day trolling posts.
I ask one question, and can't get a straight forward reply.
No my drone is not faulty.
I should have never joined this useless forum.
Nice, thanks for your help mate.You really need to read in this section buddy as there's lots of threads on this . Here's one Phantom 3 STANDARD antenna upgrade | DJI Phantom Forum.
Sounds like you have your antenna right but you always try different ways to see where yours does the best .
Use the search in my signature and type in the middle whatever you want info on and it will show you the threads on it .
You really have to do a little research in here as it's all been done and if you don't look you will miss something that just might
be what your after .
Here is an itelite on mine View attachment 34281 to answer ..what is an itelite...It's a panel antenna and you do have to do some work to install it which you will see in that link. I know it's a pain to have to go through some of these long threads but you really will see what folks have had to learn by doing
them .
That antenna will cost you around 120 bucks +shipping but has made mine do well .
