Phantom 3 Professional help
Hello all,
I have recently picked up a phantom 3 pro. It was sold as brand new but I am having problems syncing the rc to the aircraft. The aircraft is displaying red solid less and front and fast flashing lights at the rear. The RC if flickering very fast between red/green. The app won't connect to the aircraft but I am able to control the gimbal dial remotely from the rc. I have tried updating firmware via SD card and it keeps failing. Any help would be appreciated.
....Hello all,
What app do you have installed?..... You need the DJI GO app ..... not the DJI G0 4 app.... not saying that's the problem but its a common mistake.
I believe the aircraft should be be able to fly without a device/app so not sure the mobile device is the problem. I have tried to install the latest firmware by SD card which continuously fails. I have re linked the rc and phantom pro but still the same issue.
After Updating the AC firmware a TXT-file is written to the SD-card named "P3X_FW_RESULT_AB.txt".
It tells you if the Upgrade was successful or what went wrong.
Most likely "HD downlink is disrupted".
RC status light blinks Red/Green/Red/Yellow....
Page 28 in the User Manual:
Useless video.
Did you check the TXT-file on the SD-card?
Can you move the gimbal/camera up and down?
Don't install the propellers!
Can you start the motors using CSC (Combination Stick Command)?
If so:
Do the motors react to all different stick commands/movements?
Do you get telemetry data in the DJI GO App?
If so:
The drone and remote are connected properly.
Do you get a camera immage in the GO App?
If not:
The drone does NOT send a video signal to the remote.
RC status LED is flashing Red/Yellow/Red/Green.....
Possible reason: Loose or broken gimbal ribbon cable.
The camera should however record to the SD-card.
Check if it does.
.txt results
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.11.0020.bin
Result: Failed.
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Failed.
Packet: P3X_FW_V01.09.0060.bin
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:15 remo-con disconnect======
Result: Failed.
Result: Failed.
========== 2014.01.01 00:02:36 remo-con disconnect======
========== 2014.01.01 00:01:08 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:00:38 remo-con disconnect======
Packet: P3X_FW_V01.10.0090.bin
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:16 remo-con disconnect======
Result: Failed.
The gimbal will tilt up and down left and right from the controller.
The CSC command doesn't initiate anything or start the motors
The motors will not operate at all
The app doesn't recognise anything, aircraft is disconnected, I have tried with both iPhone and Android. The android phone has a charging symbol in the corner of the screen when plugged into the rc but the iPhone doesn't display anything.
The camera does record video using the shoulder shutter button straight to the sd card.
Thanks again.
What is the model number of your RC?
Linking can be done either through the app or with a manual linking process. Since you don’t have access to the app, have you already tried the manual linking process?
Please stop trying to change the FW until you have a better handle on what’s happening. Also, would you mind posting your LOG_AB file? This is NOT the same as the RESULTS file you already posted.
Also, the P3P is susceptible to damage if powered on for a while without air flow. Use a small external fan directed at the AC if you’re planning to keep the AC powered up without actually flying.
If you’re interested, click here for a list of tips I often share with new P3P / P3A owners.
Reactions: tribar
Thank You
The RC is a Gl300A (C1)
I have linked the rc to aircraft manually.
The log file:
[00014142][01 00] Firmware upgrade finished successfully.
[00014255]Done.
[00014284]Packet [C:\P3X_FW_V01.11.0020.bin] resumed, card sn [0xb0ce198b].
[00014323]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014389]Version checking[2]...
[00014437][03 06][00] v2.1.6.9 -> v2.4.20.50 need upgrade.
[00014497][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014532][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00027063][11 00][00] device not detected.
[00039590][11 01][00] device not detected.
[00039669][12 00][00] v1.7.0.0 -> v1.12.0.0 need upgrade.
[00039760][12 01][00] v1.7.0.0 -> v1.12.0.0 need upgrade.
[00039840][12 02][00] v1.7.0.0 -> v1.12.0.0 need upgrade.
[00039914][12 03][00] v1.7.0.0 -> v1.12.0.0 need upgrade.
[00052445][15 00][00] device not detected.
[00052505][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00052639][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00052695][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00052725][01 00][05] v1.32.5432 -> v1.32.5432
[00052756][01 01][00] v1.5.2735 -> v1.32.5432 need upgrade
[00065286][08 00][00] device not detected.
[00065331][09 00][00] v1.6.0.4 -> v4.1.0.0 need upgrade.
[00065363]Done.
[00065395]Firmware upgrading[2]...
[00065529][01 01] Firmware upgrade start...
[00095792][01 01] Firmware upgrade finished successfully.
[00095840][12 00] Firmware upgrade start...
[00154520][12 00] Firmware upgrade finished successfully.
[00154568][12 01] Firmware upgrade start...
[00214793][12 01] Firmware upgrade finished successfully.
[00214842][12 02] Firmware upgrade start...
[00273223][12 02] Firmware upgrade finished successfully.
[00273278][12 03] Firmware upgrade start...
[00331686][12 03] Firmware upgrade finished successfully.
[00331745][17 00] Firmware upgrade start...
[00409822][17 00] Firmware upgrade finished successfully.
[00409867][17 01] Firmware upgrade start...
[00469487][17 01] Firmware upgrade finished successfully.
[00469540][03 05] Firmware upgrade start...
[00538586][03 05] Firmware upgrade finished successfully.
[00538947][03 06] Firmware upgrade start...
[00889682][03 06] Firmware upgrade finished successfully.
[00892616][19 00] Firmware upgrade start...
[00902952][19 00] stop streaming timeout, continue upgrade.
[01046558][19 00] start streaming timeout, continue upgrade.
[01076593][19 00] Firmware upgrade finished successfully.
[01076650][09 00] Firmware upgrade start...
[01129035][09 00] Firmware upgrade finished successfully.
[01129103][04 00] Firmware upgrade start...
[01187451][04 00] Firmware upgrade finished successfully.
[01187485]Done.
[01187516]Version checking[3]...
[01187586][03 06][05] v2.4.20.50 -> v2.4.20.50
[01187666][03 05][05] v34.2.0.9 -> v34.2.0.9
[01187705][04 00][05] v1.48.0.0 -> v1.48.0.0
[01200237][11 00][00] device not detected.
[01212771][11 01][00] device not detected.
[01212864][12 00][05] v1.12.0.0 -> v1.12.0.0
[01212936][12 01][05] v1.12.0.0 -> v1.12.0.0
[01213020][12 02][05] v1.12.0.0 -> v1.12.0.0
[01213091][12 03][05] v1.12.0.0 -> v1.12.0.0
[01225622][15 00][00] device not detected.
[01225700][17 00][05] v1.1.1.7 -> v1.1.1.7
[01225812][17 01][05] v1.0.2.7 -> v1.0.2.7
[01225867][19 00][05] v1.0.8.96 -> v1.0.8.96
[01225898][01 00][05] v1.32.5432 -> v1.32.5432
[01225930][01 01][05] v1.32.5432 -> v1.32.5432
[01238463][08 00][00] device not detected.
[01238508][09 00][05] v4.1.0.0 -> v4.1.0.0
[01238546]Packet upgrade failed at version checking.
[00012628]========== remo-con disconnect. boot(15) ============
[00012662]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xb0ce198b].
[00012693]Packet upgrade start...
[00012731]Packet checking...
[00012770]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012833]Done.
[00012866]Version checking[1]...
[00012945][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013029][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013067][04 00][00] v1.48.0.0 -> v1.48.0.0
[00025611][11 00][00] device not detected.
[00038152][11 01][00] device not detected.
[00038347][12 00][00] v1.12.0.0 -> v1.12.0.0
[00038430][12 01][00] v1.12.0.0 -> v1.12.0.0
[00038527][12 02][00] v1.12.0.0 -> v1.12.0.0
[00038626][12 03][00] v1.12.0.0 -> v1.12.0.0
[00051162][15 00][00] device not detected.
[00051251][17 00][00] v1.1.1.7 -> v1.1.1.7
[00051371][17 01][00] v1.0.2.7 -> v1.0.2.7
[00051427][19 00][00] v1.0.8.96 -> v1.0.8.96
[00051470][01 00][00] v1.32.5432 -> v1.32.5432
[00051503][01 01][00] v1.32.5432 -> v1.32.5432
[00064044][08 00][00] device not detected.
[00064113][09 00][00] v4.1.0.0 -> v4.1.0.0
[00064152]Packet upgrade failed at version checking.
[00012635]========== remo-con disconnect. boot(15) ============
[00012670]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xb0ce198b].
[00012703]Packet upgrade start...
[00012742]Packet checking...
[00012779]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012843]Done.
[00012874]Version checking[1]...
[00012944][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013024][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013068][04 00][00] v1.48.0.0 -> v1.48.0.0
[00025610][11 00][00] device not detected.
[00038149][11 01][00] device not detected.
[00038233][12 00][00] v1.12.0.0 -> v1.12.0.0
[00038325][12 01][00] v1.12.0.0 -> v1.12.0.0
[00038414][12 02][00] v1.12.0.0 -> v1.12.0.0
[00038514][12 03][00] v1.12.0.0 -> v1.12.0.0
[00051046][15 00][00] device not detected.
[00051136][17 00][00] v1.1.1.7 -> v1.1.1.7
[00051255][17 01][00] v1.0.2.7 -> v1.0.2.7
[00051303][19 00][00] v1.0.8.96 -> v1.0.8.96
[00051339][01 00][00] v1.32.5432 -> v1.32.5432
[00051374][01 01][00] v1.32.5432 -> v1.32.5432
[00063908][08 00][00] device not detected.
[00063961][09 00][00] v4.1.0.0 -> v4.1.0.0
[00063999]Packet upgrade failed at version checking.
[00012632]========== remo-con disconnect. boot(15) ============
[00012665]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xb0ce198b].
[00012699]Packet upgrade start...
[00012736]Packet checking...
[00012771]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012912]Done.
[00012948]Version checking[1]...
[00013028][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013105][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013151][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013266][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support.
[00013303][11 00][00] v2.0.0.33 -> v1.8.0.0
[00013412][11 01][00] v2.0.0.33 -> v2.0.0.33
[00013515][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013615][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013715][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013795][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026331][15 00][00] device not detected.
[00026415][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026551][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026601][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026643][01 00][00] v1.32.5432 -> v1.32.5432
[00026679][01 01][00] v1.32.5432 -> v1.32.5432
[00039213][08 00][00] device not detected.
[00039283][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039322]Packet upgrade failed at version checking.
[00012948]========== remo-con disconnect. boot(15) ============
[00012983]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xb0ce198b].
[00013015]Packet upgrade start...
[00013057]Packet checking...
[00013098]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013167]Done.
[00013202]Version checking[1]...
[00013279][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013358][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013399][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013503][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support.
[00013539][11 00][00] v2.0.0.33 -> v1.8.0.0
[00013658][11 01][00] v2.0.0.33 -> v2.0.0.33
[00013763][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013847][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013937][12 02][00] v1.12.0.0 -> v1.12.0.0
[00014026][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026560][15 00][00] device not detected.
[00026648][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026775][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026826][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026862][01 00][00] v1.32.5432 -> v1.32.5432
[00026990][01 01][00] v1.32.5432 -> v1.32.5432
[00013076]========== remo-con disconnect. boot(15) ============
[00013112]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xb0ce198b].
[00013152]Packet upgrade start...
[00013190]Packet checking...
[00013227]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013295]Done.
[00013329]Version checking[1]...
[00013404][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013483][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013525][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013629][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support.
[00013666][11 00][00] v2.0.0.33 -> v1.8.0.0
[00013764][11 01][00] v2.0.0.33 -> v2.0.0.33
[00013846][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013942][12 01][00] v1.12.0.0 -> v1.12.0.0
[00014027][12 02][00] v1.12.0.0 -> v1.12.0.0
[00014130][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026670][15 00][00] device not detected.
[00026749][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026872][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026924][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026962][01 00][00] v1.32.5432 -> v1.32.5432
[00027001][01 01][00] v1.32.5432 -> v1.32.5432
[00039547][08 00][00] device not detected.
[00039604][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039643]Packet upgrade failed at version checking.
[00012657]========== remo-con disconnect. boot(15) ============
[00012691]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xb0ce198b].
[00012725]Packet upgrade start...
[00012769]Packet checking...
[00012808]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012874]Done.
[00012911]Version checking[1]...
[00012994][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013094][03 06][00] v2.4.20.50 -> v2.4.20.18
[00013138][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013234][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support.
[00013273][11 00][00] v2.0.0.33 -> v1.8.0.0
[00013393][11 01][00] v2.0.0.33 -> v2.0.0.33
[00013503][12 00][00] v1.12.0.0 -> v1.10.0.0
[00013603][12 01][00] v1.12.0.0 -> v1.10.0.0
[00013788][12 02][00] v1.12.0.0 -> v1.10.0.0
[00013903][12 03][00] v1.12.0.0 -> v1.10.0.0
[00026449][15 00][00] device not detected.
[00026538][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026659][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026711][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026746][01 00][00] v1.32.5432 -> v1.30.5036
[00026789][01 01][00] v1.32.5432 -> v1.30.5036
[00039324][08 00][00] device not detected.
[00039391][09 00][00] v4.1.0.0 -> v3.0.0.10
[00039428]Packet upgrade failed at version checking.
[00012666]========== remo-con disconnect. boot(15) ============
[00012702]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xb0ce198b].
[00012739]Packet upgrade start...
[00012785]Packet checking...
[00012823]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012894]Done.
[00012928]Version checking[1]...
[00013002][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013083][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013138][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013269][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support.
[00013306][11 00][00] v2.0.0.33 -> v1.8.0.0
[00013403][11 01][00] v2.0.0.33 -> v2.0.0.33
[00013516][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013603][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013698][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013798][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026339][15 00][00] device not detected.
[00026427][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026552][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026602][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026648][01 00][00] v1.32.5432 -> v1.32.5432
[00026683][01 01][00] v1.32.5432 -> v1.32.5432
[00039221][08 00][00] device not detected.
[00039327]Packet upgrade failed at version checking.
[00014516]========== remo-con disconnect. boot(15) ============
[00014559]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x97f3b969].
[00014592]Packet upgrade start...
[00014630]Packet checking...
[00014666]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014827]Done.
[00014868]Version checking[1]...
[00014939][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014997][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015046][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015159][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015278][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015314][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015407][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015487][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015587][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015666][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028210][15 00][00] device not detected.
[00028282][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028389][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028448][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028485][01 00][00] v1.32.5432 -> v1.32.5432
[00028519][01 01][00] v1.32.5432 -> v1.32.5432
[00041058][08 00][00] device not detected.
[00041108][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041146]Packet upgrade failed at version checking.
[00014541]========== remo-con disconnect. boot(15) ============
[00014577]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x97f3b969].
[00014613]Packet upgrade start...
[00014651]Packet checking...
[00014687]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014759]Done.
[00014793]Version checking[1]...
[00014865][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014946][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014989][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015105][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015226][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015261][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015346][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015431][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015520][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015620][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028155][15 00][00] device not detected.
[00028236][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028365][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028431][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028467][01 00][00] v1.32.5432 -> v1.32.5432
[00028502][01 01][00] v1.32.5432 -> v1.32.5432
[00041122][08 00][00] device not detected.
[00041191][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041234]Packet upgrade failed at version checking.
[00012553]========== remo-con disconnect. boot(15) ============
[00012589]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x97f3b969].
[00012629]Packet upgrade start...
[00012669]Packet checking...
[00012710]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012781]Done.
[00012822]Version checking[1]...
[00012900][03 06][00] v2.4.20.50 -> v2.4.20.50
[00012981][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013030][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013141][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013261][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013298][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013405][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013484][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013581][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013664][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026209][15 00][00] device not detected.
[00026286][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026430][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026485][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026521][01 00][00] v1.32.5432 -> v1.32.5432
[00026565][01 01][00] v1.32.5432 -> v1.32.5432
[00039101][08 00][00] device not detected.
[00039167][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039203]Packet upgrade failed at version checking.
[00014649]========== remo-con disconnect. boot(15) ============
[00014687]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x97f3b969].
[00014724]Packet upgrade start...
[00014763]Packet checking...
[00014806]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014874]Done.
[00014909]Version checking[1]...
[00014988][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015068][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015112][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015233][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015348][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015385][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015563][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015642][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015721][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015801][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028342][15 00][00] device not detected.
[00028434][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028572][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028631][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028676][01 00][00] v1.32.5432 -> v1.32.5432
[00028715][01 01][00] v1.32.5432 -> v1.32.5432
[00041255][08 00][00] device not detected.
[00041314][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041359]Packet upgrade failed at version checking.
[00016468]========== remo-con disconnect. boot(15) ============
[00016508]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xda8fbe49].
[00016551]Packet upgrade start...
[00016597]Packet checking...
[00016785]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016861]Done.
[00016908]Version checking[1]...
[00017150][03 06][00] v2.4.20.50 -> v2.4.20.50
[00017237][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017287][04 00][00] v1.48.0.0 -> v1.48.0.0
[00017395][11 00][00] v1.8.0.0 -> v1.8.0.0
[00017650][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017690][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017790][12 00][00] v1.12.0.0 -> v1.12.0.0
[00018019][12 01][00] v1.12.0.0 -> v1.12.0.0
[00018099][12 02][00] v1.12.0.0 -> v1.12.0.0
[00018195][12 03][00] v1.12.0.0 -> v1.12.0.0
[00030891][15 00][00] device not detected.
[00030980][17 00][00] v1.1.1.7 -> v1.1.1.7
[00031121][17 01][00] v1.0.2.7 -> v1.0.2.7
[00031181][19 00][00] v1.0.8.96 -> v1.0.8.96
[00031375][01 00][00] v1.32.5432 -> v1.32.5432
[00031426][01 01][00] v1.32.5432 -> v1.32.5432
[00043963][08 00][00] device not detected.
[00044181][09 00][00] v4.1.0.0 -> v4.1.0.0
[00044221]Packet upgrade failed at version checking.
[00016542]========== remo-con disconnect. boot(15) ============
[00016730]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xda8fbe49].
[00016868]Packet upgrade start...
[00016914]Packet checking...
[00016967]Packet vlink 01.11.0020 <-> 01.11.0020.
[00017039]Done.
[00017230]Version checking[1]...
[00017302][03 06][00] v2.4.20.50 -> v2.4.20.50
[00017387][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017596][04 00][00] v1.48.0.0 -> v1.48.0.0
[00017729][11 00][00] v1.8.0.0 -> v1.8.0.0
[00017842][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00018032][11 01][00] v1.8.0.0 -> v2.0.0.33
[00018110][12 00][00] v1.12.0.0 -> v1.12.0.0
[00018211][12 01][00] v1.12.0.0 -> v1.12.0.0
[00018290][12 02][00] v1.12.0.0 -> v1.12.0.0
[00018533][12 03][00] v1.12.0.0 -> v1.12.0.0
[00031076][15 00][00] device not detected.
[00031171][17 00][00] v1.1.1.7 -> v1.1.1.7
[00031456][17 01][00] v1.0.2.7 -> v1.0.2.7
[00031512][19 00][00] v1.0.8.96 -> v1.0.8.96
[00031557][01 00][00] v1.32.5432 -> v1.32.5432
[00031743][01 01][00] v1.32.5432 -> v1.32.5432
[00044289][08 00][00] device not detected.
[00044373][09 00][00] v4.1.0.0 -> v4.1.0.0
[00044420]Packet upgrade failed at version checking.
[00156614]========== remo-con disconnect. boot(15) ============
[00156662]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xda8fbe49].
[00156707]Packet upgrade start...
[00156756]Packet checking...
[00156804]Packet vlink 01.11.0020 <-> 01.11.0020.
[00156888]Done.
[00156935]Version checking[1]...
[00157030][03 06][00] v2.4.20.50 -> v2.4.20.50
[00157129][03 05][00] v34.2.0.9 -> v34.2.0.9
[00068912]========== remo-con disconnect. boot(15) ============
[00068958]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xda8fbe49].
[00069001]Packet upgrade start...
[00069056]Packet checking...
[00069114]Packet vlink 01.11.0020 <-> 01.11.0020.
[00069191]Done.
[00069237]Version checking[1]...
[00069323][03 06][00] v2.4.20.50 -> v2.4.20.50
[00069402][03 05][00] v34.2.0.9 -> v34.2.0.9
[00069460][04 00][00] v1.48.0.0 -> v1.48.0.0
[00069578][11 00][00] v1.8.0.0 -> v1.8.0.0
[00069698][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00069823][11 01][00] v1.8.0.0 -> v2.0.0.33
[00069922][12 00][00] v1.12.0.0 -> v1.12.0.0
[00070007][12 01][00] v1.12.0.0 -> v1.12.0.0
[00070107][12 02][00] v1.12.0.0 -> v1.12.0.0
[00070207][12 03][00] v1.12.0.0 -> v1.12.0.0
[00014835]========== remo-con disconnect. boot(15) ============
[00014883]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xda8fbe49].
[00014934]Packet upgrade start...
[00014987]Packet checking...
[00015036]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015120]Done.
[00015173]Version checking[1]...
[00015259][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015340][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015394][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015519][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015639][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015686][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015787][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015867][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015953][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016058][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028608][15 00][00] device not detected.
[00028708][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028828][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028889][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028938][01 00][00] v1.32.5432 -> v1.32.5432
[00028995][01 01][00] v1.32.5432 -> v1.32.5432
[00041544][08 00][00] device not detected.
[00041610][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041660]Packet upgrade failed at version checking.
[00016727]========== remo-con disconnect. boot(15) ============
[00016768]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xda8fbe49].
[00016812]Packet upgrade start...
[00016859]Packet checking...
[00016948]Packet vlink 01.10.0090 <-> 01.10.0090.
[00017000]Done.
[00017046]Version checking[1]...
[00017117][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00017202][03 06][00] v2.4.20.50 -> v2.4.20.28 need upgrade.
[00017257][04 00][00] v1.48.0.0 -> v1.48.0.0 need upgrade.
[00017458][11 00][00] v1.8.0.0 -> v1.8.0.0 need upgrade.
[00017576][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017619][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017707][12 00][00] v1.12.0.0 -> v1.11.0.0 need upgrade.
[00017788][12 01][00] v1.12.0.0 -> v1.11.0.0 need upgrade.
[00017887][12 02][00] v1.12.0.0 -> v1.11.0.0 need upgrade.
[00017968][12 03][00] v1.12.0.0 -> v1.11.0.0 need upgrade.
[00030514][15 00][00] device not detected.
[00030607][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00030721][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00030788][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00030835][01 00][00] v1.32.5432 -> v1.32.5432 need upgrade
[00030888][01 01][00] v1.32.5432 -> v1.32.5432 need upgrade
[00043435][08 00][00] device not detected.
[00043509][09 00][00] v4.1.0.0 -> v3.0.0.10 need upgrade.
[00043555]Done.
[00045601]Waiting for user confirm...
[00055648]Timeout, start upgrade automatically.
[00055734]Firmware upgrading[1]...
[00016238]========== remo-con disconnect. boot(15) ============
[00016281]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xda8fbe49].
[00016330]Packet upgrade start...
[00016378]Packet checking...
[00016426]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016480]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0).
[00016529]Done.
[00016574]Version checking[1]...
[00016650][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016735][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016786][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016910][11 00][00] v1.8.0.0 -> v1.8.0.0
[00017050][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017097][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017204][12 00][00] v1.12.0.0 -> v1.12.0.0
[00017304][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017405][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017504][12 03][00] v1.12.0.0 -> v1.12.0.0
[00030051][15 00][00] device not detected.
[00030139][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030279][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030438][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030486][01 00][00] v1.32.5432 -> v1.32.5432
[00030532][01 01][00] v1.32.5432 -> v1.32.5432
[00043086][08 00][00] device not detected.
[00043157][09 00][00] v4.1.0.0 -> v4.1.0.0
[00043202]Packet upgrade failed at version checking.
[00016249]========== remo-con disconnect. boot(15) ============
[00016295]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xda8fbe49].
[00016342]Packet upgrade start...
[00016399]Packet checking...
[00016452]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016499]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0).
[00016545]Done.
[00016589]Version checking[1]...
[00016683][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016764][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016839][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016964][11 00][00] v1.8.0.0 -> v1.8.0.0
[00017083][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017129][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017212][12 00][00] v1.12.0.0 -> v1.12.0.0
[00017318][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017397][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017497][12 03][00] v1.12.0.0 -> v1.12.0.0
[00030050][15 00][00] device not detected.
[00030138][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030273][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030354][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030401][01 00][00] v1.32.5432 -> v1.32.5432
[00030451][01 01][00] v1.32.5432 -> v1.32.5432
[00043004][08 00][00] device not detected.
[00043076][09 00][00] v4.1.0.0 -> v4.1.0.0
[00043130]Packet upgrade failed at version checking.
Thank You
The log file:
[00014255]Done.
[00065363]Done.
[01187485]Done.
300A is ok for a P3P, though it is old. That along with the fact that your AC has the original old motors indicate that this kit is probably 6+ years old or so. If it has been sitting idle for years, that alone has been known to cause problems. For instance with the batteries, RC USB board, NAND components, etc.
Great that the manual link process worked, but you didn’t tell us if that changed anything. For example, the rear lights? Are they now blinking yellow slower than before? What about outside where GPS is available? Do they then go green? Are you able to start the motors outside?
FYI that it’s easy to simply attach the text file rather than paste it’s entire contents into a post.
As you’ve probably noticed, the LOG_AB shows that your AC is currently using the latest FW, so it would be expected to “fail” if you try to install it again.
Also, the LOG_AB shows one of, if not the most common problem with P3Ps. Modules 8 and 15 show as not detected. This often also shows as “No Image Transmission” in the app, but with no app access you don’t see this yet.
This problem could have manifested due to an extended idle time (NAND flash data degradation) or by keeping it powered up for long periods with no fan blowing on the AC (component overheating failure). Note that the tiny fan on the gimbal is so ineffective that it is basically decorative. This is why we always tell people to use a small external fan when not flying.
You should be able to search and find an enormous amount of posts related to no image transmission and modules 8/15 not detected. Also, many with regard to RC/AC connectivity issues such as the USB board in the RC, using data cables (as opposed to charge only cables), plus developer options on your mobile device.
Click here for the most referenced troubleshooting chart with regards to P3Ps.
[ I just tried to edit that link into my prior message, but again got the maddening “Oops” error message which appears so often lately. As such, I’m stepping away from the forum again for a while ]
Thank You
The log file:
[00014255]Done.
[00065363]Done.
[01187485]Done.
[00012833]Done.
[00012843]Done.
[00012912]Done.
[00013167]Done.
[00013295]Done.
[00012874]Done.
[00012894]Done.
[00014827]Done.
[00014759]Done.
[00012781]Done.
[00014874]Done.
[00016861]Done.
[00017039]Done.
[00156888]Done.
[00069191]Done.
[00015120]Done.
[00017000]Done.
[00043555]Done.
[00016529]Done.
[00016545]Done.
"0800 and 1500" not detected your going to need your gimbal board flashed! if the namd is still good you might save it. take the camera off and connect to rc You are connected if you have gimbal control.
