Phantom 3 Professional Firmware v1.5.0030
Question:
I only be able make 2 short flights at night....for those who had drfting problems on 1.4, are they solved on this new 1.5?
Im still not 100% sure......
one other thing I noticed what I had multi flight mode on before update and turned off durring so had to turn it back...
Question:
At least my drifting problem is resolved.
Reactions: Mordor and bobmyers
No drifting here, never had any, don't want any.
Please don't send me any. Hahaha ahhh.
The recent update was helpful in correcting that drift error for many here. ;-)
RedHotPoker
i just purchased a p3, and it had 1.3 installed. everything was fine. i upgraded to 1.5 and my RAW photos had blue and magenta pixels in the underexposed dark areas of the photograph. i thought my sensor had gone bad, so i exchanged the quadcopter for a new one. with the new one, in 1.3 RAW images were fine, then i upgraded to 1.5 and the pixellation was back, resulting in unusable photos. i've tried using the cleaner app which made things worse. anyone else experience this issue?
photo 1 - RAW with pixelation
photo 2 JPG with no pixelation from same shot
photo 3 RAW with pixelation at bottom
weird....try reset all camps on photo mode, in settings ;-)
Thanks for the feedback about 1.5 drifting, guys!
I've reset all camera settings and the RAW photos are still unacceptable. I believe there's an issue upgrading directly from 1.3 to 1.5 as this is the second P3P that it happened to. I might exchange this unit for another. Hopefully DJI can get this sorted out.
1.5.3 still allows for a downgrade to 1.4.1, correct? If you suspect it is FW related on your original Phantom and your replacement Phantom, perhaps try to downgrade to 1.4.1 and check it out there.
P.S. - I like your username if it means what I think it means. Tagalog?
thanks! it means exactly what you think LOL
I did downgrade to 1.4 and the problem persisted. perhaps it's an issue going straight to 1.5 straight from 1.3?
So i caved in and updated to fw 1.05.03. My RC is still at 1.3.x.
I had read before that the new updated had caused some range issues etc... whats the latest word on that? Those who updated the RC also, have you noticed anything better or worse? thanks
Not sure about range issues, haven't tried anything far yet but I am getting bad vibrations when hovering...it's not the props because this wasn't happening with 1.4...I know others are having this problem with vibration when hovering
..otherwise it flew awesome, best I've seen it so far, no "no signal" issue and no drifting...anyone having the vibration issue have a solution yet?
This looks a little like the clipping warnings you get in adobe camera raw. Check your setting if you are using camera raw
How is the vibration issue identified...is it clearly visible during a hover?
Make the first "log" flight with 1.5.....did have 2 break signals about 500 meters distance and 30 meters high....maybe it was a coincidence....
Man i miss so much 1.1.9fw.....
As I posted in the other thread. I did get the gimbal vibration after updating to 1.5 last night. I downgraded back to 1.4 and problem disappeared.
Who cares if the gimbal vibrates as long as the video is stable.
ctlfreak
