that sucks. would love to see a video of the log with your stick bottoms showing.
Here ya go:that sucks. would love to see a video of the log with your stick bottoms showing.
Wow what do you do for work? Are you a detective? Haha nice catchDJI might claim that this was caused by a Pilot error collision at 0:10 sec into the Video you input forward collective pitch into the remote and exactly after it act like if it collided with something, then at 0:12 is look like there is a secondary impact, that make it spin even harder until it dies on the ground.
Good luck !
Edit: Also if you look the forward and vertical speed indicator it does give data that would confirm this theory...
My 2 cents..
Also i noticed you often give 100% stick into the controls, might i advise against such aggressive flight in urban area...No need to input more then 60% stick input, unless you need to make a emergency altitude/trajectory change...
No, i'm normally what the detectives are looking for !Wow what do you do for work? Are you a detective? Haha nice catch
Thankfully you can look at this flight in a 3D space and see there was literally nothing around me.DJI might claim that this was caused by a Pilot error collision at 0:10 sec into the Video you input forward collective pitch into the remote and exactly after it act like if it collided with something, then at 0:12 is look like there is a secondary impact, that make it spin even harder until it dies on the ground.
Good luck !
My 2 cents..
Bird?? You were 90' up and looking at the app. Just a possibility.Thankfully you can look at this flight in a 3D space and see there was literally nothing around me.
No, I didn't say it was my theory, I asked YOU if it was a possibility, not the same thing. And you did say you were making setting changes, so I didn't know if you were eyeballing the bird when it started its death dance or not.Your theory is I hit a bird.
And no, I wasn't looking at my app, I was looking directly at my drone as I was bringing it back down to me. ?!?!?! SO you're saying because DJI can claim I hit a bird - they have no responsibility!??! Seriously?
I'm just stating the obvious that DJI might claim, because from first look of this data, it looks like you gave forward pitch until .2 second before the start of the (change of attitude) and you also give a fast -100% throttle .1 sec before the crash that can be interpreted as a panic move to try to go under something like a light pole, electricity wire, or else, but failed and it hit a first time, making the aircraft suddenly loose 2m altitude and starting to spin and then 2 second later there is a second change of attitude that align with the line of a building on the map and then it fall even faster....but by all means, make up something like "secondary impact" to give a corporation an out to avoid responsibility.
Alright, someone please help me get these txt files out of the drone so we can see this flight in a 3D space so it's obvious there is nothing impacting the flight, and that no, pushing the sticks at 90 or 100% doesn't cause complete motor failure.![]()
What concerns me is that the new motors on the P-3 get fairly hot to the touch, and I don't mean just warm. I've got three DJI Phantoms, and none of the motors on the earlier models have ever gotten as hot to the touch.
I say this not as result of a long flight or aggressive flying, but simply as result of hovering along with some simple maneuvers. I usually break in the motors this way for the first several flights, and will end the flight with 50% battery remaining during these initial flights. I had not found any resistance in any of the motors as they all turn freely with little resistance.
Has anyone else noticed the temperature of the motors after flight, hot.
Motor failure does not let the aircraft fly another 30m from 30m altitude, if motors fail it probably drops pretty fast considering it was already at low altitude, but it could be possible also that a ESC failed and the bird was trying to compensate during the crash trajectory.
Can we have the google map coordinate (address/street of where this flight occurred), then it will be easy to see if there's anything that could of caused the first change of attitude and or impact ...?
