Phantom 3 gimbal issues , please help
Hi, I noticed that when start phantom 3 , gimbal set normal position , and camera is different angle. Check please video. Camera angle is okey? Anyone have phantom 3 pro , take picture from upper side gimbal. Sorry for my bad english .
at the end of the video the camera angle from above. Its ok?
Movie:
Have you tried to re calibrate the gimbal with in the pilot app? Go into camera settings and select advanced settings. You should see it there.
You can check out what your angle is P3 camera ? center or litte right?
Mine is about 1 degree to the right. my videos and pics look fine.
The gimbal will fluctuate and won't always center perfectly unless in flight. this is not abnormal.
Move the Phantom around while on and see if the gimbal will center. I move mine around and it will center and sometimes not, but not by much.
Reactions: Lyxx
Try this,strange that it is
Be sure that the IMU Calibration is done correct.
After that do the doing following steps:
1:In DJI Pilot APP go to the Gimbal Param Settings
2:Then sellect the Gimbal Auto Calibration button then oke.
3:Ater that close the Gimabal Para Settings screen at ones when the calibration begin.
With that X mark on top right corner.
Let me know this will work.
My gimbal:)
Litchi
