Hi guys I created this small checklist its laminated and will have a metal grommet and dog tag chain to connect to the handle on the back of your controller if anyone is interested in on pm me [file]check1|none[/file][file]check2|none[/file]
Whats spelled wrong? I tried lowercase but preferred upper as its easy to read on the flyNice idea. I have a few suggestions:
- Spell check it.
- See what it looks like when not all in uppercase. It might be easier to read.
APP FUCNTIONINGWhats spelled wrong? I tried lowercase but preferred upper as its easy to read on the fly
There are lots of errors. Try copying/pasting your text into a program like Microsoft Word.Whats spelled wrong?
appreciated. This was just the first one so changes can be made. Just seeing if there is an interest if not ill use for myself as pilot that also flies manned aircraft checklists can save your butt and having one on your controller assures you will likely use itNo worries. I'm just trying to help you make it better
where have you got that data? if done properly calibrating every flight should cause zero issuesCompass calibrated every flight only risks you introducing a bad calibration imo. I have had over 50 flights and only calibrated twice
In this case, weather could be used in place of whether...APP FUCNTIONING
NORMALL
WEATHER
CORECTLY
I stopped there.
Also, are you suggesting to calibrate compass every flight or to check the sensor readings?
What's the text for that in the other checklists that have been posted?
it was intended as weather i.e possible rain, wind conditions, etcIn this case, weather could be used in place of whether...
Depending on his actual intent of meaning. ;-)
I have a factory preflight check list above my gauge cluster on the Can Am SpYder RS-S that is quite handy to read, before take off..
RedHotPoker
Good point. You're right. Thanks sir.In this case, weather could be used in place of whether...
Again, good point. I also normally just overlook those types of errors and would have in this case as well if not for the OP specifically asking, "What's spelled wrong?"I kind of figured that right off. And actually purposefully ignored the minor errors. Many folks here have a first and second language, while some frequent fliers have numerous languages to communicate with...
But English grammar, spelling and punctuation can get you more respect, from the intelligent masses. Most folks who can afford these RC hobbies are fairly well educated. You don't see many homeless people packing drones around the soup kitchens and homeless shelters of major cities. ;-)
& for those still learning English, please read more to improve your vocabulary. Ha
RedHotPoker
Agreed. But, when it comes to making a product that you're going to give/sell to someone, putting in that extra effort really countsIt really annoys me when I do it, but people generally don't mention it to me since they normally get what I mean anyway. I try to extend the same courtesy.
pm meNo link to your checklist in the post?
