Phantom 3 charging questions
Hello all
I recently picked up a Phantom 3 Advanced (i suppose for this question it does not matter the version) without a charger, what are the best option s for chargers? i will also need the power brick and whats options do i have there?
You can find a list of OEM and commonly used 3rd party battery chargers here.
He's probably referring to this:
IMHO - forget all the hubs and crap out there that sequentially charge - so in fact 3 batterys take as long to charge as connecting each in turn to the single DJI charger.
I have the 4in1 charger and it charges up to 3 batterys AND controller (P3A / P3P) simultaneously .... brilliant and cheaper than a DJI charger !!
They do a version for P3 or P4 as you choose ...
Reactions: KachemakDiver
Cool so they will do the P3 Standard no issues?
Yes because all P3's use same flight batterys ...
The only part it will not charge is the Controller used by P3S - but the DJI charger doesn't either. You use a mobile phone charger.
There are two advantages with the 4in1 ...
1. Charge rate is at the higher P3A / P3P rate and not the lower P3S rate .....
2. You charge all batts at same time seriously reducing charging time.
jeetbuzz360
