Phantom 3 advance bit rate
Using litchi not sure if it's auto in dji go what a good bit rate to use for good live stream between phantom and iPad so still have good quality but not much lag
Ok thanks for that is it auto on go app I'll check later
A reminder that your P3A's downlink bitrate is capped at around 2Mb/s and it will not be higher than that even if you set that slider in GO to something higher.
Reactions: Digdat0
I agree
the p3adv is limited to 2 mbs video stream by fw.
only the p3pro actually responds to the slider and will go to 10.
I stay at 4mbs for distance and quality ...
Reactions: Digdat0
In litchi I can select any bit rate but it locks onto a channel if select auto channel it moves the bit rate around
You can select a bit rate, but with a P3A it never exceeds about 2Mb/s no matter what you choose. A P3A is not able to go any higher than that for the downlink video.
A P3P on the other hand is able to go to ~10Mb/s for the downlink.
tom sauter
