Phantom 2 vision + V3
Hey
I bought DJ Phantom 2 Vision + with whom I have a problem because it does not connect to wifi .
I turn on the range extender and command , then the Phantom . I find the network on the phone phantom xxxx and connect . I go into the app and choose the Generals binding , and scan the code on phantomu . The BIND and this should be it. Then is switched off all together and I turn back . Under wifi Phantom seldom found, found as before this amplifier ( requires a password and write password and which connects the link is not ) He says Unable to connect to phantom .
PLEAS HELP:)
The FC 200 is the camera, you need to connect the wifi to Phantom_6227 as you did in the first step.
See this video
Hello !
But after binding disappears Network phantom ! And the only fc200 is there .
I now try to manually insert the IP adress amplifier .
I set static, by IP subnet mask , router , DNS .
Behold , the phone connects to wifi .
Everything works ok . But now he has emerged another problem . Link works for a few seconds , and then write a phantom connection broken . Then for a few seconds he connects back again write a phantom connection broken
Hello !
I found that I connect directly to the Phantom .
So I can turn off the amplifier , and is still part of the video .
It is normal that the connection is l dropping in few-ten seconds intervals ?
Or should stay connected ?
I would like to discover where the mistake is .
Now if it is normal that a direct connection is interrupted. Then an error in the amplifier .
Im asking for help
Johnboy94
