Phantom 2 FPV range is HORRIBLE
FRS
I have a sundance DJI phantom 2 from DSLRpros and my stock FPV is really bad. It twitches in and out more than it stays solid. I have absolutely no idea what kind of equipment it has ( as I'm very noob with technical stuff) I am tempted to call DSLRpros and ask if this is somewhat normal and if I can get any better quality but right now I am pretty much in the dark. I know I will probably get some "read the manual, blah blah blah" reading the manual for the FPV system doesn't do me much good since I am a noob.. any suggestions would be super appreciated.
Hard to be of much help without more details of what you really have.
You may need to change the channel on the transmitter or you could have a blow transmitter.
If you turn on the power without the antenna on it. It can over heat and blow out.
You should call DSLRpros and ask them about it. They might just say all you need to do is something very simple.
What are the FPV tx and rx? I bet is black pearl and irc 600mw, they dont work very well together...
double check if the channels are properly configured.
