Phantom 1.1.1 won't pair with TX
Bought Phantom 1.1.1 a year ago. Pulled out the stock RX & replaced it with the Futaba. All good since first flight. Just bought a P2 now, so I want to put the P1 back to original. Put original receiver back in, but now it won't pair with the stock TX (it did originally way back when). Blinking yollow light from hell. Firmware was updated, and tried it both in D-Bus and PPM.
Any thoughts?
Thanks
update: actually, the tx must be pared because the red led inside the battery tray turns off, but only when it is plugged into the assistant. But no stick response at all. When I disconnect the assistant, the yellow light then flashes. Sheesshh...
OI Photography said:
The receiver has 2 cables going to the NAZA, yes? One in X1 and one in X2. Try swapping them with each other.
Thanks for the reply, I swapped them & now it flashes red instead of yellow.
