Just added a Phantom 4 to the Squadron. It was what seemed a reasonable deal with the AC with 2 extra batteries and an Ultimaxx 3 Port Charging Hub thrown in.
The problem is that all I get are the 3 LED's blinking red (approx 1 second flash) regardless of charging set up:
* Plug in with no batteries.
* Plug in with 1 then 2 discharged batteries.
* Plug in with 1 charged battery.
* Plug in with 1 charged and 1 discharged battery
* Plug in with 2 charged batteries.
The notes on the base of the hub have LED Status descriptions for Flashing Green, Solid Green, Flashes Red, Solid Red and "Flashes Red at the same time" which indicates "Abnormal Input Power".
I can't see the DJI Charger putting out an Abnormal Charge.
Anyone else have one of these hubs and have it working as described?
The unit only has the DJI P4 Charger Connector and 17.5v Jack Plug. There are NO switches for setting Discharge Function or anything else as with the DJI Hub.
TBH, I don't see any real advantage to using these hubs as there is no real time saving when charging more than 1 battery. I get along fine with 5 P3 batteries and 2 chargers, one standard and the more powerful one for the P3 Pro.
Next is just me rambling on, skip it if you wish.
If things run as they have with my previous purchases then the P4 is about to be scrapped. I bought a P3/4k and it was withdrawn soon after. I bought a Refurb P3 Pro and the P3 Range was ditched the following day. Now that I have the P4, and things run to form, then it should be getting pulled any day soon. The P4 is actually marked as "Unavailable in Your Region" (UK) As it was, I purchased from Drones For Less which although looking like a UK website, it is actually sending stock from Brooklyn USA. To their credit, it only took 3 days to reach Glasgow, Scotland.... it took another 4 days for the courier to deliver to me, just outside Glasgow.
Minor glitch was only 1 extra battery instead of 2. It is being rectified hopefully in the standard 3 day slot.
The Charge Hub issue is awaiting the words of the wise.
Goad! I can waffle on.
Cheers, and I would appreciate any Non-Abnormal Input from you chaps.
