As a hobby/recreational YES you register yourself and use the same # on all your aircraftDo I still have to register?
As a commercial operator YES but you register each individual aircraft
**First off ringolong this has nothing to do with you personally it's just a learning opportunity for all of us**
The quote above is exactly why we are expected to learn and understand "aviation" terms etc. This is exactly how it has always been from an aviator's perspective in terms of "How low you can fly". You must maintain the MIN alt below you to the ground or any substantial object below you. GL (ground level) is terra firma or any object sitting on terra firma.This could be a 50' tree, 100' tower, or 500' tall building. This is exactly how it's been for years in aviation.
If you're flying along and you're flying at safe MIN alt of (in this instance) 500'AGL. You see a 400' tower ahead of you then you either divert around the tower or ascend the additional 400' in order to maintain your 500' MIN altitude over whatever is directly under you. Usually a pilot looks on the sectional, pics the tallest point in the sector we are flying, and adjusts our MIN alt to reflect that single point (it's usually a mountain top or tower etc).
As a responsible UAS operator we need to remain at or below 400' AGL(above ground level). The same logic goes in our situation where if you're flying along flat ground at 400' AGL and you fly over a building that is 200' high then legally when you approach the building you "can" ascend an additional 200' to cross the building and maintain your AGL height. Just remember that as soon as you cross over the building you'll need to descend that same 200' within 400' of the building to remain in the clear in terms of the regs.
Now this is a huge exaggeration (mostly) but it demonstrates why we "need" to understand aeronautical terms and practices in order to be able to integrate into the NAS safely. If we can't integrate safely then we need to find something else to do with ourselves instead of UAS operations.
You are missing his main point. It has always been this way, all along, unless you are only referring to your own understanding, which has now been changed, by the clarification.I agree, and this is exactly how I read it.
I used to stay away from high structures, but this opens doors.
Thanks for that Dirk. I am still sifting through all of this stuff. I even sent an email to FAA this morning for testing and review info to find out where that will be. I will post that when it comes out and I find out.Did some searching on another of our sites and saw this .
Might be father back in this thread and sorry if it is .
Added / Just started at the front and see it is ,whoops
NO. AGAIN, as stated earlier, Part 107 is only for COMMERCIAL operations. Hobbyist rules are not affected.soo....do i need a license if i use it for non-commercial such as taking family photos under 400ft? i've already registered my drone and paid the $5 fee.
Compare it to the cost of getting a pilot's license. If you already have a license you can skip the FAA cert test too...
Would ya mind condensing all these post so it want be so long ,I don't know how yet or I wouldIf you intend to post a question, please read the thread first.
It's probably already been asked and answered. New questions are welcome. Ones that have already been answered 10 times are not.
Not sure if this helps but this is from pages 383 and 384 of the FAA release
As discussed in more detail below, the process for issuance of a remote pilot certificate will be as follows. First, an applicant will have to take and pass an initial aeronautical knowledge test. After taking the knowledge test, the applicant will be provided with an airman knowledge test report showing his or her test results. If the applicant passed the test, the applicant will then fill out an application for a remote pilot certificate using either the FAA’s electronic application process (referred to as the Integrated Airman Certification and Rating Application (IACRA) system) or a paper application. The FAA will then forward the applicant’s information to the TSA for security vetting to determine whether the applicant poses a security risk. Once TSA notifies the FAA that the applicant does not pose a security risk the FAA will issue an electronic temporary remote pilot certificate to an applicant who applied through the IACRA system.128 This temporary certificate (valid for 120 days after receipt) will be issued within 10 business days after receipt of an electronic application, and it will allow the applicant to exercise all the privileges of a remote pilot certificate with a small UAS rating. Once all other FAA- internal processing is complete, the FAA will issue the applicant a permanent remote pilot certificate.
link:
http://www.faa.gov/uas/media/RIN_2120-AJ60_Clean_Signed.pdf
Hi Ringo!Anyone can go out and take this test to see what the questions may end up looking like.
https://www.faasafety.gov/gslac/ALC/course_catalog.aspx#catalog
What a joke about the tsa vetting us citizens. As if sticking their hands down our wife's and kids pants isn't enough. Training the public to tolerate being treated like inmates needs to stop now. I am sick of it.
