- Joined
- Dec 31, 2017
- Messages
- 29
- Reaction score
- 15
For sure. I can recall seeing 43-44 mph in the HUD before.OK then.
The data shows that your max. speed was nearly 40 mph. Is that possible?
Is it possible that someone found it in their back yard and it is being kept nice and comfy in a house somewhere?Just got back from my 10th time out. Some of the area searched today was for the second or 3rd time. I really appreciate the interest and advice from this forum, so I do wish I had better news.
Alas, I just do not.
From about 5 mins after it disconnected, I've thought that very thing. Which is why I keep checking FB, FB marketplace, etc.Is it possible that someone found it in their back yard and it is being kept nice and comfy in a house somewhere?
The max speed for this flight was 29.3 mphThe data shows that your max. speed was nearly 40 mph.
In P-GPS mode with obstacle avoidance disabled, the drone can fly at 36 mph.Is that possible?
68.7 mph! Woah.The max speed for this flight was 29.3 mph
With a strong tailwind, it can go a little faster, getting close to 40 mph.
But in atti mode with a tailwind, it can fly a lot faster.
The problem with that calculation is the assumption that the falling Phantom accelerates at 32 ft/sec²I'm afraid I've got you beat.
I would not argue with your assessment at all. I've been flying a while, so I do do things fast. (yep, I said ?). I got no thrill out of taking unnecessary risks with it, or flying fast. I do like to get good footage, at opportune times, so... yes, I got to the location ASAP.Hi @Tap2FlyCommode ,
I took a look on the CSV files.
The CSV of the last flight (when you lost the bird):
1st thing I've noticed is that you've started to push the Throttle (see rc_throttle column) after just 0.7 seconds following motors start !!
At 9.0 seconds you were up at 153 ft having just 5 (five) satellites !!
The bird acquired its GSP position just at 11.9 seconds, but at that time you were already up in the sky at 223 ft !!
At 16.3 seconds when the system confirmed Home Point Recorded you were up at 325 ft !!
Don't take me wrong, but this shows a bit nervous behaviour to the bird, and an impacient way to fly. Following the motors start, normally you should wait at ground to see the Home Point Recorded and lift up just if you have at least 12 satellites.
The column "isVideo" flag: did you had 3 unsuccessfull attempts to start video recording at 01:55.8 - 01:57.8 (2 seconds), at 03:44.4 - 03:45.8 (1.4 seconds), at 05:10.2 - 05:12.8 (2.6 seconds), and succeded at 06:00.4 - 06:26.2 (~26 seconds, that being last available data), or something went wrong inside the bird ?
The CSV from the 2nd last flight (the successfull one):
There is a strange matter, the column "gpslevel" is steady zero no matter if the bird has seen or not 1-18 satellites. Normally this level should raise to say at least 3-4 for 12 sats and further higher to 5 for more sats.
I'm wishing you to find the bird, so to have the opportunity to analize the DAT file, that will tell us what happened after you've lost the aircraft downlink. Since the last known isVideo flag was on 1, I guess it means finding the bird will let you see too the video that was recorded beyond you've lost contact.
Absolutely...I had a few mishaps. all with great endings. found drone under the hands of cooperating folks willing to return the bird no damages.Is it possible that someone found it in their back yard and it is being kept nice and comfy in a house somewhere?
It's always good to wait for the home point to be recorded, but in this incident, the OP launched and only applied throttle and rudder before the home point was recorded 16.3 seconds later.1st thing I've noticed is that you've started to push the Throttle (see rc_throttle column) after just 0.7 seconds following motors start !!
"The home point has been updated please check it on the map."It's always good to wait for the home point to be recorded, but in this incident, the OP launched and only applied throttle and rudder before the home point was recorded 16.3 seconds later.
This could not possibly have contributed to the incident.
As he had only climbed vertically from launch, the recorded home point would have been quite close to the launch point.
