P4 Firmware P4s firmware
  • Start date Start date
D
Deleted member 62848
Guest
Had this silly prompt about new firmware today,,this p4 was on old when I get it so already update to version 02.00.010 I think it was,now today's one said version 02.00.0810,,,,the firmware worked without a hitch and I just put it through its paces and seems fine but have any others had this,,I was unaware there was any new firmware
Reactions: Str1776
OK I must be only 1,this stumps me,anyone have same numbers here or cause I at bottom of globe it's just arrived lol
It takes a while for things to run down hill. Lol. This is an update to fix the P4 ability to load new NFZ and such. The P4 were freezing up trying to load them. It had a lot of unhappy people on the DJI forum.
OK thanks yes I thought it was bit odd,,thought it just target me ,,first I heard of it,,,oh ha I better pay more attention,I normally read what I install but this time I jump the gun a bit and not read properly, thanks Ian
I just got the same update prompt. I had to replace the camera and was worried it was something wrong with that. Glad I'm not the only one.
Thanks!
Thanks!
Well I spoke to soon... The download will not download, it just stops after a min or so of sitting on 3%...
Any ideas?
Any ideas?
Could try reinstall of the app,if a firmware prompt shows again try again,,I do all my firmware with OTG adapter,,always works for me,,what's you method
Thanks for the info! I think its working at the moment *crossing fingers* Once I disconnected it from my home wifi it started downloading fine and has not stopped yet. I will keep that in mind if it fails again!
Thanks!
Hi sorry To bother you what is the OTG adapter
I’m getting the same upgrade firmware request
Hi um this is otg adapter cable,,,just always worked this what for me,,,yup once downloaded it go straight in to p4 with usb from remote,,,it's stays conected when doing this even though the usb from device been has been unplugged to connect this cable adapter
Reactions: Str1776
Once again this is a prompt,,you are not forced to do it unless it gets locked,,,,it's your choice to update,,if you don't you keep getting that annoying reminder...
Ps,,you not bother me,I'm just having bad day:)
Reactions: Str1776
sansuciboy1
