P4Pv2 - Flight .dat logs
Does the drone purge the .dat flight logs as it fills memory? I was looking to download all my flight logs and found only flights 69-165, so the first 68 logs were not present.
Thanks.
If it is like the other Phantoms, Yes. Once memory is full, the files will overwrite. That is for the aircraft files. If you are looking for the device .dat that is different.
Reactions: davinco
Thanks. That is what I was suspecting. What is the difference between the device.dat and the aircraft files?
Jerry P
