- Joined
- Aug 1, 2015
- Messages
- 485
- Reaction score
- 526
- Age
- 50
No. It's not compatible.
Is it possible ocu-sync uses the same improved lightbridge that the P4P uses, except ocu-sync has the Wi-Fi option on the Mavic? After all, both are rated to support the identical 4.3 mi range. This would also allow the new goggles to work with both craft. Do you think DJI is that smart?I have not tried it. The P4P uses Lightbridge and the Mavic uses OcuSync.
Oddly enough the new CrystalSky controller will work with the Mavic, Phantom 3 Pro, Phantom 4, Phantom 4 Pro, etc. It seems like the $300 display that comes with the P4P+ is a slightly watered down version of the 5" CrystalSky display... i.e., it does not have the physical buttons on the right hand side of the display. It will be interesting to see if the P4P+ controller is itself actually backwards compatible with all drones.Would be nice if we could bind the p4pro remote to mavic. Anyone know ???
The only thing I know for sure is they both aren't using the same technology. It's probably similar though.Is it possible ocu-sync uses the same improved lightbridge that the P4P uses, except ocu-sync has the Wi-Fi option on the Mavic?
As for the goggles, I'd be surprised if they aren't compatible with the P4P too.
