- Joined
- May 14, 2018
- Messages
- 91
- Reaction score
- 21
- Age
- 55
@BudWalker or other wizards of drone logs,
I was wondering if you could take a quick look at the following and tell me why my new P4P 2.0 is slowly drifting in hover. Depending on which way I turn leading into the hover, it will start to slowly rotate on its own and may go clockwise or may go counterclockwise. It will also eventually stop turning if I let it sit long enough. I made sure to be in a large field away from anything for this flight.
Looking at the logs with my limited knowledge I see that the yaw and mag-yaw are sometimes drifting apart or back together which seems to correspond to what I am seeing.
I found a similar issue with the Mavic Air that DJI claims will be fixed with firmware soon. Is it possible that the new P4P 2.0 is using similar code or hardware that makes it have this same issue?
2018-06-16_08-41-35_FLY008.DAT
