The image was focus by tapping the centre of the screen using AF, should I be using MF?
Settings were in manual mode -2 -2 -2, iso100, auto white balance. What should o be changing to ensure that I am getting better quality stills?
You're turning down the camera settings and then complaining about the quality? Come on! Try shooting in DNG with stock settings and see how that does.
I only ever turn down the settings when I'm doing video, not when I am taking stills.
OK, will try this. I am open to any ideas, just trying to improve on the stills I have taken.
How do you suggest about going about the focusing on the P4P?
Thanks for the info!
I have fairly extensive experience with the P4 and the P4 Pro. The still images from the Pro are better. At this level of refinement of the technology I suppose it's a personal opinion as to whether the improvements are minor or huge. There is a law of diminishing returns. You do have to be more aware of focusing with the P4 pro, so in that respect it is a little more hands on than the camera in the P4. The Pro camera also does better with lower light/high iso photos. The advantage of the P4 is that you can get decent photos buy just pointing and shooting whereas the Pro version gives you a camera that necessitates just a little more attention. That is pretty much the case though with any camera, whether it flies or is handheld. A better camera does not automatically result in better pictures. You have to know how to use it to it's best advantage. Photographers will willingly spend the extra money to get a camera that will give better results.
Given what you are trying to take an image of you may want to try manual settings. My uneducated guess is that this ties into what your settings were based upon what the camera chose. For example, what was your fstop when the picture was taken? That will affect the depth of what is in focus and what is not. For example if the fstop was 2.8 the depth of field will be short and as you get away from the object of focus chosen (foward or backward in the image) the less in focus it will be. It looks to me like the house in the middle of the image is the most in focus, so if you had a low fstop like 2.8 it explains why everything else looks out of focus. If you choose something like fstop of 8 that would increase the depth, though you also have to adjust other settings accordingly.Will try -1 0 0 and focusing on closer objects when the weather fines up a little. I read that focusing in the middle of the screen was the best idea (which is what I did on this particular still). Won't focusing on close objects make the objects in the distance blurry? So much to learn coming from the more point and shoot P4..
Someone might have a youtube video or something that explains these settings and how to use them on the P4P. Here is a basic article that explains more. Focusing Basics | Aperture and Depth of Field
And yes you should probably focus on something in the middle if you're going far a larger shot like your example.
The lens is equivalent to a 24mm on a full frame SLR so it's quite wide and so has very good depth of field anyway.Won't focusing on close objects make the objects in the distance blurry? So much to learn coming from the more point and shoot P4.
Can you post the raw images? Maybe others can help.Did another trial this afternoon..
0, 0, 0, f/10 iso 100 tap to focus at a close imagine & a far away image, still not too happy with the results. depth of field doesn't seem to be anywhere near as good as what others are achieving. also tried f/8 and f/11, still with no luck.
Looks as though objects in the distance are quite noisy.
Really not too sure what else I could be doing incorrectly. I am 100% tapping to focus before every shot..
This has the equivalent of a 24mm lens so should have plenty of depth of field regardless of settings.still not too happy with the results. depth of field doesn't seem to be anywhere near as good as what others are achieving.
If you aren't familiar with camera settings, it's easy to make a mess of things.also tried f/8 and f/11, still with no luck.
There is no V2.0Is the Phantom 4 Pro + and Phantom 4 Pro V2.0 the same drone? Or are there upgrades to the 2.0?
What is h365? What is Flog?Nonsense, stop drinking the koolaid. I can show you great low light video on the P4 as well. He even states its not a Pro dslr sensor.......Its better for stills. The Flog is useless, the H.365 had banding issues. Video is on par wit the P4, stills are better with the P4P. My comment was directed at whomever called the sensor a RX100 clone. Its NOT. I'm a pro photographer, trust me that theres more to a image from an RX100 than just the sensor.
Good question!
Errr, yes it is. Sony Exmor R CMOS 20MP backlit. Model IMX183. Exactly the same as in the RX100III.
