P4, how to balance props?
I have a P4. I have a prop balancer. The balancer requires that it's shaft runs through the prop. So how to balance a P4 prop?
Thanks.
What kind of prop balancer do you have?
I am planning to use this concept after sanding roughness off new ones ..
Good luck with what you chooses.
Ron
Sent from my SM-G935V using PhantomPilots mobile app
Ron
Geez, Thanks. Simple and elegant, just the way I like it.
That one is not going to work.
Try the Du-Bro 499 or the SpeedyTM prop balancer. Both come with a prop balancing rod that fits the P4 props.
Here's a good how-to on balancing props:
Ron
I made one of those and it didn't work so well. The point on the nail that goes into the center of the prop might rest a little off center so the balance is off as it is tilted not being centered. The setup msinger suggests works better.
I found a piece of spring steel rod at the hobby shop that fits snug into the prop hole and just roll it on a level tin can which seems to work too. One could put a taper on the rod too with a drill and a file.
Nachobriefs
