P3se uprgrade ??
Helo after few months i have try to fly my bird - i use DJI GO 3.1.8 - when I try to start i have information - aircraft is locked and I need upgrade to 1.9.20 firmware - what should I do ?? I still i want to use it in FCC mode - any suggestions ??
After a few months You have what .....................?
I have P3SE - just back from the service after accident .
I normally connected via P3Standard because version 3.1.8 does not have a P3SE link. After installing the Russian version 3.1.18 I will still receive information about lock my bird and
necessarily update to 1.9.20 firmware . This is normal situation ??
No, it is not normal. I advise you to first use the regular version DJI Go 3.1.30. And then see if you can fly.
If this succeeds, you can try again with DJI Go 3.1.18.
New djigo 3.1.31 + iphone with ios 9, new dji account and still same problem - app see my bird as P3 standard . Any ideas for this ??
Can you select the Ps3Se from the drop down box the photo side ways until you see the Ps3Se
