- Joined
- Apr 29, 2017
- Messages
- 26
- Reaction score
- 1
- Age
- 47
I am boosted.. Kinakailangan ang Pagtiyak sa SeguridadIm not.so luky like you. My.ps3 have low 5.8 signal from one of two bird leg dipole.
Wow. How did you reach before boosting? Im boost only for 5.8.
Does anyone have problems out of new firmware update??
Maybe 5000 ft max..Wow. How did you reach before boosting? Im boost only for 5.8.
5000ft = 1500m. is very big distance with stock config.Maybe 5000 ft max..
Revised P3s Debug downgrade
How to...
Never skip a version
Always run the firmware first (pass or fail)
then run that same firmware again with the Debug file also...
Then format the card and run the next lower Firmware
then again with the Debug file and so on..
If you get sensor errors follow the steps below to fix them..
If you have v1.08.10 with a +
Then start here
v1.08.10 -> v1.08.10 + Debug
v1.08.10 -> v1.07.9
v1.07.9 -> v1.07.9 + Debug
(v1.07.9 -> v1.7.94 If you get "Sensor Error" if not skip this step...) I am waiting for clear info on the next step from here for further downgrade..
v1.05.7 -> v1.05.7 + Debug
v1.05.7 -> V1.5.75 If you get "Sensor Error" if not skip this step...) I am waiting for clear info on the next step from here for further downgrade..
and So on.. Here is a list..
v1.0.14
v1.0.17
v1.0.2
v1.01.3
v1.02.4
v1.03.5
v1.04.6
v1.05.7
v1.5.75
v1.06.8
v1.07.8
v1.07.9
v1.7.94
v1.08.10
There are new and older Firmware Versions not listed...
Anyone Know them?
Without exact firmware numbers
Links are hard to find..
1.7.94 link
P3C_FW_V01.07.0094.bin
1.5.57 link
P3C_FW_V01.05.0075.bin
The rest listed are here
DJI Phantom Accessories & Tips - Phantom Help
Some news for your downgrade test? After reading many post seems the problem for many bird still upgrade from1.2.4I installed 1.2.4 FW but had compass errors over and over and then all of a sudden, somehow, the calibration took. So no more compass error but now the controller won't link. I pressed the reset link button on the AC for a few seconds, then turned the wheel on RC to the left and toggled S2 3 times. I could see they both turn green for a second, and at the same time the app shows a green signal for only a second, then it's back to red and unlinked. What the mother FK!! Gonna throw this thing in the **** garbage lol. I have now been trying to relink RC to AC for half hour....no luck. Ugh!!!
Use this method.. (If the gimbal light is blinking green and red) it is working NEVER stop a F/W process!!! wait for 1 -3 minutes after the light goes solid red or green... (debug does weird things) If you use my method the app will say it is done.. I would debug 1.5.7..after v1.05.7 to V1.5.75 Firmware bin file is corrupted, download it again from the DJI offical website.
Well, my how to is in the first few posts.. http://www.phantompilots.com/thread...med-working-update-sensor-error-fixed.108575/Could someone please tell me where the debug file is located and whether or not I actually need to use it? I have tried putting the next lower firmware on my sd card, but it does not transfer to the a/c. I am assuming I need to debug... please correct me if I am wrong
This is a very good question!!!Ok, so lots of people appear to have successfully downgrade FW from 1.8.n down to 1.5.n Of those, how many actually saw an improvement. Everything I read was that no one seem to get (back) an improved range. If thats true then why bother???
