- Joined
- Oct 23, 2016
- Messages
- 209
- Reaction score
- 44
- Age
- 53
I have used the Current Debug method for downgrading the P3P and the P3A..
Which has proven itself to work!!
So looking at how it is used...
I believe that this would work for us in the P3S side...??
Please read my posts and others' post here.. (before you do anything!!)
forcing fw downgrade with P3X_FW_DEBUG · Issue #4 · mefistotelis/phantom-firmware-tools · GitHub
There is no instructions... But I have given a good description of what it does...
WARNING!! WARNING!! WARNING!! Do this at your own risk...
I have not seen this done... I have heard of no one trying this on the P3S....
This is what you need is a zero Bit file..
with the according name on the sd card.
P3X_FW_DEBUG (pro)
P3XW_FW_DEBUG (P3-4K)
P3S_FW_DEBUG (ADV)
P3C_FW_DEBUG (STA)
Warning!! Use must know how to use this..
The way it works on the P3P is that ..
After a downgrade, you place the debug file on the sd.. (on the root same as Bin) with that same version F/W again and re-downgrade..
Then you are able to go down to the next lower F/W and do it all over again
Never skip a version... And use this method to ensure that the R/C get downgraded too..
Again this Debug downgrade is Untested!!!
Please Do this at your own Risk!!!G (pro)
P3S_FW_DEBUG (ADV)
P3C_FW_DEBUG (STA)
Again there are no true instructions...
The Downgrade "Debug use" on the P3S
WILL have to be written Right here...
The provided zip file is all the zero bit P3 Debug files
P3X_FW_DEBUG (pro)
P3S_FW_DEBUG (ADV)
P3C_FW_DEBUG (STA)
P3S_FW_DEBUG (ADV)
P3C_FW_DEBUG (STA)
