P3P Replacement Prop Wrech
Has anyone found a replacement? I broke mine. This is the wrench that slips around the motor body like a band wrench. P2 wrenches or those that fit on the splines dont work on the new P3s. Thanx!
I've never seen this part sold anywhere. Perhaps someone here will send you their wrench. Most people never use them. It's usually easiest to just hold the motor with one hand and tighten the prop with the other.
Reactions: TTSupra628
While the included wrench was nice I always felt I was going to torque the rotors too hard and break the motor structure. I do what @msinger stated and use two hands to put the props on and take them off.
That wrench is not needed if you hand tighten the props.
src72
