P3P Disconnect REHASH!
My p3p will disconnect ('disconnect' warning and black and white FPV display) after the first minute and 45 seconds of liftoff every time. I can land the bird, turn off the r/c, turn it back on, and it will reconnect and I can finish my flight until the battery cries 'UNCLE".
It does the same thing with either my Android or my IOS devices.
I'm certain it's not my r/c USB connection and the above facts would seem to eliminate the app, but I'm baffled.
Flight records just show the first flight ending, nothing else.
Any help would be greatly appreciated.
Look at the aircraft .dat files. Disconnect's don't affect those. That might tell you what is going on. It could also be a slow device issue Android or IOS. Seeing the end of the flight records on your device is normal for downlink loss. That is why you look at the .dat files on the AC when that occurs. With all the new updates from the apps, it really eats up the processor and memory. That is the other possible issue.
Reactions: MotorCycle-Man
akos9703
